Sponsored by: Innova
Single/Double chamber stealth box?
Old Nov 13, 2008 | 10:19 AM
Gideon's_Test's Avatar
Gideon's_Test
Default Single/Double chamber stealth box?
I'm planning on building a stealth box for my '99 FRC. The box will accomodate a pair of JL Audio 8W1v2-4 subs, and will be powered with a JL Audio 300/4 amp bridged to two channels (150x2@4Ohms).
JL Audio 8W1v2-4 Specs
Reccommended Sealed Enclosure Volume: 0.375 ft³ (net int.)
TS parameters:
F3 (Hz) 52.5
Fc (Hz) 57.4
Qtc 0.78
FS (Hz) 34.55
Qes 0.508
QMS 6.260
Qts 0.47
Vas 0.66
My question is: Will it sound better with a board dividing the box into two chambers? Or should I leave it as a single volume? I'm leaning towards dividing it into two, but would welcome comments either way.
SQ has a higher priority than db & I'm hoping for improved transient response with the 8"..
Also, I believe that the 8W1v2-4 is the best 8" sub for my application, but if anyone has any comments on this, feel free to speak up...
Thanks!
Old Nov 13, 2008 | 11:05 AM
Gideon's_Test
I think I found my answer: http://forums.corvetteforum.com/audi...oofer-box.html
Feel free to post if you think my situation is different than the user in the above post.
