Sponsored by: Innova
ABSOLUTELY INCREDIBLE SUB!!!
Old Feb 3, 2002 | 09:03 PM
webdzynes's Avatar
webdzynes
Default ABSOLUTELY INCREDIBLE SUB!!!
I've heard most and had a JL Audio 12w3 sub in my C5.
Just installed their new 12w7. This thing is so clean an
hits so hard, I feel like I just went 10 rounds with Tyson!
A Must for audiofiles and base nuts alike!!
[Modified by webdzynes, 10:42 PM 2/20/2002]
Old Feb 4, 2002 | 12:28 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (webdzynes)
Where did you pick it up? How much? What type of enclosure? How much power and what amp/model? What's its mounting depth?
Signed Jealous one needing trans work first.
Old Feb 4, 2002 | 11:11 AM
mrkln's Avatar
mrkln
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (92TripleBlack)
Yes, I want to see this install as well. I am still investigating my subwoofer options as we speak. I also want to know how much power you are driving it with and how much you had to give for it. :cheers:
Old Feb 4, 2002 | 03:52 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (mrkln)
Yes, same questions as above. I would love to compare.
George
Old Feb 10, 2002 | 06:28 PM
DPC5's Avatar
DPC5
My vote goes to the Kicker S12L7 12" Square Sub :yesnod:
[Modified by DPC5, 7:48 PM 2/13/2002]
Old Feb 10, 2002 | 08:39 PM
mrkln's Avatar
mrkln
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (DPC5)
DPC5,
How much air space did you give the L7 and how much power are you feeding it? I am still trying to decide my sub setup. I was leaning towards 2 10" L7s but I haven't ruled out a single 12" L7 like your setup.
I still really like the JL W7 but you can't buy a grill for it and that is just to much of a risk to take since I do carry stuff in the back of my car every now and again.
Old Feb 12, 2002 | 01:21 AM
mr.vet's Avatar
mr.vet
Man that is a nice set up :yesnod: :yesnod: :yesnod:
Old Feb 13, 2002 | 10:06 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (mr.vet)
The 10w7 is like 800 bucks a piece. The problem is that they require sooo much airspace that you may not have enough in the rear center compartment. Also the 10w7 is not a typical 10"sub (wont fit in a 10" hole). Im my case I cannot get them because of the mounting depth. They are very tall if you have ever seen one in person compared to a typical woofer. Most of us dont have enough power to move one more less two.... :cry
I do agree... they are some of the badest woofers on the market, but I think I'll pass...
Old Feb 13, 2002 | 11:23 AM
mrkln's Avatar
mrkln
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (ICULUKN-C5)
ICULUKN-C5,
Not sure where you are getting your information from but the 10W7 can be yours for $499. Still not cheap but it is definately not $800. It also only requires 1.25 cubic feet for a sealed enslosure which will easily fit into the center hole. Now, it you want a ported enclosure, then the install becomes a little more tricky as you need 1.5 cubic feet. They do require a mounting depth of 9" (8" for the driver plus an inch of space for the polepiece vent to the panel behind the driver) which is rather deep but still possible.
I am strongly considering a 10W7 right now. :cheers:
Old Feb 13, 2002 | 10:10 PM
DPC5's Avatar
DPC5
Mr. Vet: Thanks
I'm running a Soundstream 1000sx at 2ohms mono (1000 clean watts :yesnod: ) to the sub. It's in the Kicker supplied wedge
box. I'm also running a optima yellow top, but the only thing
missing now is a cap.
Old Feb 14, 2002 | 11:53 AM
MHLY01's Avatar
MHLY01
I have two 10W7 going into my truck now in a fiberglass box with two Arc Audio 1500 going to each. I will be putting a 12W7 in my vette as well soon. They sound unbelieveable.
Old Feb 14, 2002 | 11:21 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (MHLY01)
Sorry about the price misunderstanding .. you are right .. they are 499.. The 12 was closer to number I quoted earlier. In the rear of a C5 you only have 1.6 cubic feet of space. Are you only going to run 1- 10"? I currently have 2 10's now. Do they not require big power to drive it??
Old Feb 15, 2002 | 09:40 AM
mrkln's Avatar
mrkln
The local shop told me a minimum of 750W for a 10W7 and 1000W for a 12W7. I didn't even want to know about the 13W7. :eek:
I was going to go with a single 10W7 in a 1.5 ft3 ported box but I think I have decided on a pair of Image Dynamics IDQ10D4v.2. I can get them online for $200/pair. I just can't justify the extra $300 to own a 10W7. :rolleyes:
mrkln's Avatar
mrkln
Ooops. Double post. :nono:
[Modified by mrkln, 7:59 AM 2/15/2002]
Old Feb 18, 2002 | 05:24 PM
Tracy Focht's Avatar
Tracy Focht
Navigator
Nice install DPC5.....who did the install, and how do you like the L7?
Old Feb 18, 2002 | 08:33 PM
DPC5's Avatar
DPC5
Default Re: ABSOLUTELY INCREDIBLE SUB!!! (Tracy Focht)
Thanks Tracy, I did all of the work myself. I love the L7, I've got plenty of power to it. I think my next project will be a slightly larger box than the original Kicker Wedge. I would like to get 1.5 or 1.75 cu ft, I know it would help with some of the lower frequency's.
Jim
Old Feb 19, 2002 | 11:56 AM
Tracy Focht
Navigator
True...and if it's sealed, the 2.0 sealed is the optimum (.707 SQ alignment) enclosure, but if you use the 1.75 vented...you'll really be amazed! :eek:
Awesome install! :cheers:
To ABSOLUTELY INCREDIBLE SUB!!!
Old Feb 20, 2002 | 11:36 PM
webdzynes's Avatar
webdzynes
Sorry for the delay -
I picked my sub up for $545 including tax out the door!!! I built a VERY solid 1.5 Cubic foot box (which isn't very big) just to try this out. (I'm going to rebuild the box changing the dimensions a bit so it will sit nicely in the center well.) The real news is that I am powering it with a JL Audio 500/1 and it hit so loudly (and I like it LOUD) that I had to turn the gain down!! The JL reps say it could use more power to really get the best out of it. Well, I can't imagine getting "more" out of this - that is if I still want to hear afterwords.
Here's the best part -
Percussion feels like you been punched
Extended base guitar notes make you feel like an Alka Setzer tablet in water - makes your hair stand on end!!!
..and NOTHING I have ever heard compares to the sound quality - and thats my main interest!! ( I run the sub along with 2 sets of MB Quarts and an ADS amp). GET THIS SUB!!!
I'll post pics after I make the new box!
Old Feb 21, 2002 | 01:00 AM
MHLY01's Avatar
MHLY01
The sub sounds unbelievable and is worth every penny in my mind. I have two 10W7 in a rather small box, 1.1 cubic ft each with only 450 watts to each. We are trying to stay in the 301-600 class when we compete. Anyway, this sub sounds tremendous and has the best impact and SQ of any sub I have heard, and I have competed in and out for over 8 years. You would never guess they are 2 10"s 450 is enough power to each, but the sub can take way more and you can feel it. There is way more potential there.
In a vette, you could do a 12W7 in the center storage compartment, The mounting depth will be close though and remember, this thing is not light. It will add some weight to your car. I will probably be putting a 10W7 in my vette along with 6 Focal 5.25" mini subs in the front. I will post some pics of my truck soon and will keep you updated on the vette system.
Old Feb 21, 2002 | 09:11 AM
mrkln's Avatar
mrkln
Hey, have any of you guys heard about the Image Dynamics IDMAX. It is 12" SQL driver. I know that it is not a W7 but I heard that it is pretty much the #2 sub this year (behind the W7 of course). I can pick one up for $300. Quite a bit cheaper (and lighter) than a W7.
Hmmmmmm............
