08 Coupe Upgrade Question
I did an Evelyn Wood speed read through most if not all the audio posts here. Didn't find what I was looking for. The only upgrade to my factory (non-Bose) system is add a Infinity Bass Link to the back of the drivers seat in the storage area. I have since bought a new JL Audio Stealth Box from a friend, complete with the JL sub for $200.00 cash. Needless to say I added a single channel 400 watt amp where the Infinity Bass Link was and installed the JL box. I think it sounds great. I can now turn down the bass setting on the factory head unit and use the amp/JL box. I don't want to spend the cash changing out the factory head unit. My question is... finally.... would a aftermarket set of speakers in the doors like Pioneer Premier PRS720's or the like give me better sound? I want to keep my spending under $400.00 including the speaker adapter panels. Suggestions?
You can get custom cut plates for $45 shipped.
I went with Polk db6501 components for $120 shipped on ebay.
That leaves you $235 to spend on an amp (2 ch for just fronts, or 4 ch for rears also) and whatever other gizmos you'll need for the install. Or you could spend a bit more on the speakers.
I like having the rear speakers playing (many around here recommend against it), so I went with a 5 channel amp ($200 shipped) and some JVC CS-FX502 5.25's for the rear.
Also, about the rear speakers. I have read that some folks say they are not needed and don't do much. My rears can really be heard. I have the front/rear adjustment set dead center. I would say I can hear the sound as 55% rear and 45% front. I would think about an upgrade to the rear as well. I'm looking for a link that shows how to access the rear speakers.
Thanks again.
I was going to wait until I was done with my entire install, but since you asked..... CLICK HERE
As far as I know, all C6 models have 5.25" speakers in the rear.
The question regarding rear speakers isn't whether you can hear them or not it's what they contribute to the sound stage. Honestly if you can pick out the rear speakers you have it faded too much to them, all they really are intended for rear fill. I was skeptical of front speakers only but have found that concentrating on the front stage is the way to go for sure, I don't miss rear speakers a bit in either my vert or my Z06.
