Sponsored by: Innova
Replacing Bose radio
Old Feb 18, 2002 | 05:28 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Replacing Bose radio
I was informed that if I replace the Bose head unit in my 1991 convertible the SES light will come on. Why is this, and how do I stop it from happining? At the moment I have the stock Bose head unit with 2 Eclipse amps and four Eclipse speakers. The Bose head unit just died and I would like to replace it with an Alpine CDA 7875.
Using the stock head unit was a mistake, the soud quality was terrible.
Thanks for anyones help,
Doug
Old Feb 18, 2002 | 09:31 PM
Dave84/76's Avatar
Dave84/76
Default Re: Replacing Bose radio (C44ever)
You will need 2 1K-ohm resistors(radio shack). Connect one end of one resistor to the grey/black wire behind radio. Connect one end of the other resistor to the purple/white wire behind radio. Then connect the other end of both resistors to switched 12volts(red wire on after market radio). http://temp.corvetteforum.net/c4/dave8476//TSBDoc.1.JPG http://temp.corvetteforum.net/c4/dave8476//TSBDoc.2.JPG http://temp.corvetteforum.net/c4/dave8476//TSBDoc.3.JPG
Old Feb 19, 2002 | 08:04 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Replacing Bose radio (Dave84/76)
You may not even need to do that. Most cars don't need it. I've had 3 decks from different makers in my 92 and never had a problem.
Old Feb 19, 2002 | 11:52 AM
ROADAPPLE's Avatar
ROADAPPLE
Thank you DAVE84/76 your information was greatly appreicated. That's the information I was looking for incase my new radio flashes a code.
Thanks again,
Doug
To Replacing Bose radio
