Sponsored by: Innova
C5 head unit question ?
Old Aug 30, 2009 | 11:03 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default C5 head unit question ?
Can i keep my head unit in my c5 and jus do a swap out of the speakers ? my fronts are coming apart and i would like to run some diffenrent ones ? do they make a wire adaptor kit so i can jus plug and play or do i need to run all new wiring ?
Old Aug 30, 2009 | 03:51 PM
markcz's Avatar
markcz
The 3.5" twiddlers are just standard 4 ohm speakers, and IIRC you don't need an adapter since they connect with the standard spade plugs (see if pentavolvo can verify that). Polk db351 and Boston Acoustic S35 are popular replacements, but ANY 2-way aftermarket speaker will sound better than the OEM paper speakers.
If the big bass speakers are what you need your best bet would be to find a cheap set of takeoffs on the forum.
