Sponsored by: Innova
Amp wiring pics
Old Feb 9, 2010 | 07:20 PM
bowtiebubba's Avatar
bowtiebubba
Default Amp wiring pics
I would like to see some pics of amps that have been custom & neatly wired. Im getting ready to do mine & just dont want it to look like a bunch of wires stuck on it.
Old Feb 9, 2010 | 08:59 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
first before u even mount the amp hook it up and make sure everything works, start the car make sure there is no wine etc. that way when you mount the amp and cut wires down to length odds are it will work great and there will be no suprises
basically run wire under carpet to where u want it and cut a small slit and run the wire out and hook up to amp
Old Feb 9, 2010 | 09:06 PM
Kale's Avatar
Kale
dont cut your carpet, use a board.
Old Feb 9, 2010 | 10:49 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
+1. You can also map things out to cross wires as well:
Old Feb 10, 2010 | 10:33 AM
bowtiebubba
Great looking work. Do you use any type of terminals on the end of your speaker wires going to the amp?
Old Feb 10, 2010 | 12:13 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
gold plated crimp ring terminals.
To Amp wiring pics
