Sponsored by: Innova
Guru wiring question
Old Mar 1, 2010 | 07:09 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Default Guru wiring question
I have the DNX6140 which only has pre-amp outs for front and rear(or sub) Not a seperate sub out.
I am going to be using the Alpine PDX 4.150 and Polk SR6500 6.5s
The Polks crossover accepts seperate power for mids and tweeters. The Alpine will handle this.
The question is: I want to add a Sub with additional amp. Since I'm going to need the rear pre-amp from the HU for this, I'm wondering if I can use a RCA splitter for the front pre-amp output so that I can feed the front and rear inputs on the Alpine Amp?
Old Mar 1, 2010 | 09:38 AM
Capt Steve's Avatar
Capt Steve
Yes
Old Mar 1, 2010 | 09:57 AM
simpleman68's Avatar
simpleman68
Yes you can. You'll be reducing the output voltage of the pair that you split, but you can adjust for that by setting the gains of the amps to match each other.
Scott
Old Mar 1, 2010 | 04:48 PM
nickwfd92's Avatar
nickwfd92
Does the PDX have a out on the amp for Subs, some do and you can just run a small rca from the one amp to the other.
Old Mar 1, 2010 | 05:03 PM
simpleman68
The 1.600 PDX does have a pair of outputs, but I'd rather have them out of the 4.150. Can be done in a pinch though.
If his head unit does not have the ability to set a crossover point for the sub, and I assume it doesn't as it doesn't have a set of outputs for a sub channel, then he'd probably still be better off splitting the source signal from the HU.
My old PPI had a pair of outputs on the multi-channel amp and you could select whether you wanted to use front, rear or a combo of them both for throughput.
Scott
Old Mar 1, 2010 | 05:06 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
IMO run the rears/sub from the headunit straight to the mono amp. Then run the front output from the headunit to the pdx4.150 and use y adapters
Old Mar 1, 2010 | 05:23 PM
simpleman68
Simply put and I forgot that his HU does have rear/sub outputs. I'd then expect he has the ability to control the x-over point.
We'll find out Saturday.
Scott
Old Mar 1, 2010 | 05:42 PM
De_Vette's Avatar
De_Vette
Thanks This is the route I'm going, already got my Y adapters for the front amp. I'll be sure to get plenty of pics
Old Mar 1, 2010 | 06:45 PM
Lancejoker's Avatar
Lancejoker
Looks like you're ready to go Larry.
Old Mar 2, 2010 | 04:48 AM
De_Vette's Avatar
De_Vette
Just need to decide on insulation
To Guru wiring question
