Now I'm Really Confused
I plan on using the stock amp, stock antenna, etc. There seems to be so much back and forth on the topic of 5V vs 12V vs no volts vs relays. very frustrating, to say the least. Surely, with so many people that have installed aftermarket nav units there's a definitive answer out there. Not denegrading the inout on that thread, but it seems to be in loop mode.
Jim
At the main C1 radio plug, supply 12v to the white wire at B3 whenever the radio is playing, and 5v to the yellow wire at A4 when you're listening to FM.
C6 schematics are available HERE
To see why the above is true, check out the copy/paste from a GM service manual HERE
Just FYI, on the aftermarket interface adapters the blue wire is at pin B3, so if you're still using the OEM amp/speaker setup your white B3 wire already has 12v. If you're reception complaints are with AM, there's nothing more you can do. If FM is the problem, try adding the 5v at A4. Connect the blue 'antenna' wire from the HU to a 5v regulator, then connect the regulator output to A4.
Jim
Would the 6 or 8 volt be better or is 5 volts enough?
EDIT: I just bought a NTE-960 from Fry's. 5 Volt Positive Voltage Regulator. Seems to work for other people, I'm sticking with it. Now if I want to get fancy, I have a left over switch from an IPOD adapter that I could wire in so I can turn off the 5 volt signal when using AM radio. Does anyone know if that would be a good idea????
When I powered up I got most of the FM stations, but some of them sounded like there was a helicopter in the background. I removed the center console again and clipped the 5 volt line. VIOLA, all FM and AM stations were clear as can be and all came in great. To me the 5 volt trick was just a bad deal. Can't say for everyone else, just my experience.
