Sponsored by: Innova
One More
Old Nov 22, 2010 | 10:38 AM
okie08vette's Avatar
okie08vette
Default One More
The FAQ says that there is a chance or whine after replacing the HU and that this product will elimate it,
http://www.parts-express.com/pe/show...number=265-012
My question is that since I am not installing a aftermaket amp then I would not be using the harness with the RCA connectors so I am not sure how to hook up this device, any help would be appreciated.
Old Nov 22, 2010 | 11:11 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
If you're not installing an aftemarket amp there wouldn't be anywhere, or need, to install.
Old Nov 22, 2010 | 11:52 AM
okie08vette
Great, Thanks
Old Nov 22, 2010 | 07:26 PM
markcz's Avatar
markcz
Maintaining the oem amp with an aftermarket HU is when the GLI's are needed most. The interface that plugs into the main harness should take the line-level signal from your new radio via the RCA plugs, connect the 'devices' between them (you need 2 for front/rear signals).
Old Nov 22, 2010 | 10:06 PM
okie08vette
Hey I really appreciate your help, my lack of understand comes is that I am under the impression that since I am not adding a amp then I would not even use the interface cable with the RCA plugs on it just leave it off completely, but do I understant that I should use it and connect both ends of the GLIs to the RCA connectors coming out of the interface cable?
Old Nov 22, 2010 | 10:53 PM
BigDs_C6's Avatar
BigDs_C6
How about some details on the system... looks like your car is a C6?
Do you have a factory Bose system?.. Are you using any interface modules?.. What model HU are you installing?
I installed a new head unit using 2 PAC interface modules in my C6. I also installed an aftermarket amp to run a single sub... I have no whine what so ever and I didn't use any GLI's.
D
Old Nov 22, 2010 | 11:15 PM
Blue Blood's Avatar
Blue Blood
I would only use the GLI if there is a problem, most people notice a decline in the quality of the audio when they are used.
Old Nov 23, 2010 | 09:34 AM
okie08vette
D
Sorry for the lack of details its a 2008 Coupe with no Bose, with On Star. Installing a Pioneer AVIC 120z and no additional components, no extra amp. Just a swap for the fractory HU with the Pioneer.
Old Nov 23, 2010 | 01:48 PM
EliteGreg's Avatar
EliteGreg
You will connect the head unit to an interface to the factory amp. You will use line-level (RCA) outputs on the interface.
Old Nov 23, 2010 | 11:18 PM
okie08vette
Have a noticeable static noise from the radio with out the engine running, Pioneer AVIC 120, 20008 Coupe, no bose. Do you think I need the GLI since this is not alt noise I am suspecting a ground problem any thoughts?
Also no alt noise that I can hear when the eng is running but I still have the seats out so have not driven the car but I can't hear any in park with the eng running, but lots of static when the sound is down, this happens as long as the unit is powered up.
Help?
Old Nov 23, 2010 | 11:24 PM
Blue Blood's Avatar
Blue Blood
Static with all sources, radio, CD, IPod??? If radio only, check antenna feed line is connected.
Old Nov 24, 2010 | 08:33 AM
okie08vette
Does not matter what input is selected still get the static hum all the time even with it in off mode but still powered up.
Old Nov 24, 2010 | 04:23 PM
markcz's Avatar
markcz
The GLI's should fix it if the static is new since the aftermarket HU was installed. That's a very common problem when using new HU and oem amp setup.
Old Nov 29, 2010 | 11:16 PM
bell9440's Avatar
bell9440
did this fix the prob?I have the same set up and am curios of you results.
To One More
