Sponsored by: Innova
New audio install
Old Oct 20, 2011 | 01:00 AM
vickvette's Avatar
vickvette
Default New audio install
I finally got my new audio system installed
Since the subwoofer is in the stealth box, I can just take out the panel and completely hide it with the stock carpeted cover. And there I can put the big luggage :-)
HU - Kenwood Excelon KDC-X995
2x Amps - Kenwood Excelon xr-4s /front comp speakers/ and xr-5s /rear speakers and subwoofer/
Fronts - Focal 165 KRX2
Rear - Focal 130 CA1 /just to fill out the space/ :-)
Subwoofer - Focal Access 25 A1
Capacitor - Precision Power C.10F
Custom stealth box for sub from Dennis
Door speaker plates - Dennis
Amp kit - Dennis
Install and custom box - Reseda, CA
I was thinking about adding some lightning to the box but since it doesn't improve the sound I just left it out :-)
Old Oct 20, 2011 | 07:56 AM
kedar's Avatar
kedar
St. Jude Donor '12
Awesome! How does it sound?
Old Oct 20, 2011 | 12:02 PM
Thrash's Avatar
Thrash
I had the pillar tweets installed like this on my C5, getting ready to see if I can do it again on my C6? I just can't dig those bulging mods I've seen. Great job and nice work ...
Old Oct 20, 2011 | 12:47 PM
mdiiulio's Avatar
mdiiulio
How do you like the tweeter's sound from that position?
Old Oct 20, 2011 | 03:13 PM
Thrash's Avatar
Thrash
On mine it really pushed the stage up and forward. I think there would be too much separation if they were any higher. The sound was crisp, clear and wide, a great mod ...
Old Oct 20, 2011 | 11:30 PM
vickvette's Avatar
vickvette
I agree with Thrash. My tweeters sound amazing, but I still think the best place for the tweeters is where "Thrash" installed them, a lil higher than I did. I was going to do it the same way but couldn't find his post with pics so I left it for the install shop in the a pillars
Old Oct 20, 2011 | 11:44 PM
vickvette's Avatar
vickvette
Amaaaaaazing. It's my first "real" audio system in the car. I still have to play with all the adjustments since I got the car back this monday and didn't really have time for it. But as I played some classical pieces, I can clearly hear every single note in the violin solos and I can hear the fingers moving in guitar solos. And of course snapping fingers I've never heard before in a piece I've listen to zillion times. Overall, I think I'll be spending more time in my car than home!!!!!
I've the sweet sound of my exhaust, okay a lil mean and if not, there's my sound system!!!
Old Oct 21, 2011 | 12:53 PM
Thrash's Avatar
Thrash
I agree, it sounded amazing (I don't have that C5 car now), I got a C6 in June and will see if I can pull it off with it ...
Old Oct 21, 2011 | 05:31 PM
mdiiulio's Avatar
mdiiulio
Thanks for opinions guys. I'm looking to do something similar with those same Focal Tweets.
Old Oct 22, 2011 | 10:23 AM
Thrash's Avatar
Thrash
Here is what mine looked like, notice the tweet is no higher than the clip base and rib bottoms, and about even with the vent bottom. I used way too much hot glue, just a spot or two should do it. Draw a circle where it will go from the outside, drill a small hole dead center, cut the vinyl in small radial cuts from the center to the circle edge (to fold under) and tape them back away from the edge, then SLOWLY drill with a quality hole cutter -from the inside-out, so as not to damage the vinyl. Good luck ...
Old Oct 22, 2011 | 11:21 AM
mdiiulio's Avatar
mdiiulio
Old Oct 26, 2011 | 12:06 PM
Gadget01's Avatar
Gadget01
Is that hot-melt glue holding those tweeters in place? Good luck with that...
Old Oct 26, 2011 | 04:08 PM
Thrash's Avatar
Thrash
I did put a bit much, but it held like a rock (was a rock). On a do-over I'd put globs on maybe just 4 spots, as I couldn't use a bracket there. Point was being sure the case would not move when the swivel tweeter was moved. What would you do?
Old Oct 27, 2011 | 02:31 PM
Tarheels1's Avatar
Tarheels1
Nice thread.
Old Nov 15, 2011 | 09:24 PM
Roz's Avatar
Roz
How do you like the Kenwood HU? I'm considering this unit but I'm extremely curious of the quality of the bluetooth streaming capabilities.
PM me if you wish - thanks in advance!
Old Jan 14, 2012 | 05:36 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I have been looking also, and as far as I know none of the Kenwoods this year had Bluetooth streaming. I am wondering if the new units will have it. My local stereo shop says that bluetooth streaming further decreases the bit count and none of the brands really do a great job at streaming vs. a direct connnection.
Old Jan 14, 2012 | 09:03 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
new Kenwoods have it
To New audio install
Old Jan 14, 2012 | 09:54 PM
X-Ravin's Avatar
X-Ravin
I was thinking about sticking my tweeters there as well, but why didn't a bracket work to hold it on there?
Old Jan 15, 2012 | 10:52 AM
TrueBlueCoupe
Now I just need you to get me one 6 weeks earlier!
Old Jan 15, 2012 | 08:50 PM
knox79's Avatar
knox79
Cruising
Thrash
Where did you find the swivel brackets for your tweeters? I like the look of what you did with yours, thinking of doing that with mine.
