Sponsored by: Innova
Got all the stuff!
Old Nov 16, 2011 | 02:25 PM
Thrash's Avatar
Thrash
Default Got all the stuff!
So I am preparing to do the consummate audio install in the next week. I did all the planning, got lots of forum advice, selected the right components, ordered everything ... and now I'm ready to start taking the interior apart. I'll be posting step-by-steps on each level soon and attached is a photo of all the parts for grins. This is very exciting ...
Old Nov 16, 2011 | 03:36 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Looking good. I look forward to following your experience and photos as I will be doing the same thing in the next few months.
Don't skimp on the instructions of taking everything apart and how you route all of the wiring.
Are you changing the head unit? ........ doing a rear view camera?
Old Nov 16, 2011 | 03:58 PM
Thrash's Avatar
Thrash
No, so sad, no HU for now, but will likely do that down the road. I will be posting all the steps: removal of seats, carpet, consoles, elec. connectors (each and every one, which will be a big plus), install of 3 deadening layers, Valentine One hack & custom install, amps, line driver, processor, speakers, thermal barriers, wiring, Big-3, pillar tweets, cell-phone booster and portable urinal ...
Old Nov 16, 2011 | 04:06 PM
markcz's Avatar
markcz
How do you plan on attaching the amp power and big 3 wires to the B+ ?
Old Nov 16, 2011 | 04:15 PM
WAwatchnut's Avatar
WAwatchnut
IIRC, you got the Pyle coaxes for next to nothing, but I still can't believe with how thorough you're being, and the quality of the stuff that you're using, that you're going to have THE most critical part of your sound reproduction dictated by the fact that they were cheap! .
(and this is coming from someone with a soft spot for Pyle Drivers... Back in the day it was 80% of what I used to sell... Morel and Dynaudio and Vifa being the other 20%)
Everything else looks great! Have fun with the instal!
Old Nov 16, 2011 | 05:25 PM
Thrash's Avatar
Thrash
I'm doing the Big-3 thing (Alt to Batt, Batt to GND and all) and running a power lead from the B+ into the cabin & to a power block (fuses near the batt). I'm adding a multi-connect post clamp. Grounding to the frame at the pass. door.
Old Nov 16, 2011 | 05:35 PM
Thrash's Avatar
Thrash
I disagree that the 3.5" location on the doors is the most critical part, the lower 6.5's, pillar tweets and dual 10" subs are the major stage. Anyway, it's just a temp thing at worse. I like the idea of having some mid up at that level with a tweet (coax instead of just tweets) -but may put tweets there instead -or better 3.5's, depends on how it sounds. The Pyle 3.5's are decent, great specs and really heavy, I just thought this was a worthy approach, as there will be Focal tweets on the pillars. I worried about too many tweets that high. Plus I had the Pyles and why not use them? Thanks and appreciate the input, loving the forum at every post ...
Old Nov 16, 2011 | 06:01 PM
ralphsmithiii's Avatar
ralphsmithiii
This is awesome! I was about to post roughly the same type of posting as I am about to start my own install (along with a buddy of mine doing an install on his Z too) here shortly. I'll still post mine though not as thorough as yours!
Old Nov 16, 2011 | 06:17 PM
markcz's Avatar
markcz
Old Nov 16, 2011 | 06:57 PM
gsx1300r's Avatar
gsx1300r
Thrash writes: "I'll be posting step-by-steps on each level soon..."
WE WISH YOU GOOD LUCK!
I'll be watching your progress on a frequent basis! The shop manual sometimes points to a section and states remove..... wow - i frequently need more detail than that if I am not going to break things. This R&R needs to be pretty well foolproof for me - thanks in advance for your efforts.
Old Nov 16, 2011 | 10:50 PM
kedar's Avatar
kedar
St. Jude Donor '12
Looking forward to the install.
Old Nov 17, 2011 | 12:30 AM
EvilBoffin's Avatar
EvilBoffin
St. Jude Donor '09
Two Questions -
1 - Am I somehow missing your AMPLIFIERS in the pic above?
2 - Did you buy all that hardware (speakers, amps, controllers, etc.) from Rick at RAAM Audio?
Old Nov 17, 2011 | 01:47 AM
427Z0SX's Avatar
427Z0SX
Do you have the hydraulic crimper for the 6 gauge power cable?
Old Nov 17, 2011 | 04:39 AM
WAwatchnut's Avatar
WAwatchnut
Ahhhh... I missed the fact that you were putting in Focal tweeters also. If you're using them just for reinforcement, they may be okay. Id still be worried about the differences in sound between the focal and pyle tweets muddying up the sound, but you'll hear that quickly enough.
The reason I think they're critical though is that the lower midrange, mid bass, and sub, are all much less critical of the gear IMHO. Differences in quality of midrange and high frequency reproduction are quite often much more perceptible to listeners, and the difference between good and great speakers are more noticeable in the upper frequencies than lower.
Old Nov 17, 2011 | 09:40 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I am also in the process of installing an audio system in my 2011 GS coupe.
I noticed that you are going to install (2ea) 10" subs in the rear.
I may be very wrong, but that seems like overkill for a car that only has a total interior size of 52 Cu. Ft.
I am just thinking that with that much sub ... the system might sound a little 'boomy' even if pushed to even medium levels.
Maybe I am looking at this all wrong?
Old Nov 17, 2011 | 04:29 PM
Thrash's Avatar
Thrash
Originally Posted by crystalracer
Two questions -
1 - am i somehow missing your amplifiers in the pic above?
2 - did you buy all that hardware (speakers, amps, controllers, etc.) from rick at raam audio?
1) Photo switched, I forgot to label the amps. 2) No, just some of the deadening stuff, spkrs & amps from DoubleD and AudioControl from Crutchfield
Originally Posted by 427z0sx
do you have the hydraulic crimper for the 6 gauge power cable?
Yes, a friend has one I can borrow
Originally Posted by wawatchnut
ahhhh... I missed the fact that you were putting in focal tweeters also. If you're using them just for reinforcement, they may be okay. Id still be worried about the differences in sound between the focal and pyle tweets muddying up the sound, but you'll hear that quickly enough.
The reason i think they're critical though is that the lower midrange, mid bass, and sub, are all much less critical of the gear imho. Differences in quality of midrange and high frequency reproduction are quite often much more perceptible to listeners, and the difference between good and great speakers are more noticeable in the upper frequencies than lower.
With the DQXS I can control each set of spkrs X-over, level and EQ, if they sound bad I'll upgrade for sure. Thanks much.
Originally Posted by turbo6ta
i am also in the process of installing an audio system in my 2011 gs coupe.
I may be very wrong, but that seems like overkill for a car that only has a total interior size of 52 cu. Ft.
I am just thinking that with that much sub ... The system might sound a little 'boomy' even if pushed to even medium levels.
Maybe i am looking at this all wrong?
Putting in 2 because of the vert, as they will be behind the partition and also behind the top assembly when it is down (a huge blockage), thus I'll level them as is appropriate. If I had a coupe I'd do just one, I had a single 12" in my '04 coupe and it was great.
Old Nov 17, 2011 | 04:42 PM
WAwatchnut's Avatar
WAwatchnut
In a coupe, 1-10" will definitely keep up with any front end you put in, but there are advantages to dual 10's. More presence to the bass, better clarity at higher volumes, etc. Overkill for most people, but not necessarily wasted. I've been toying with the idea of adding a second 10 in mine.
To Got all the stuff!
Old Nov 17, 2011 | 04:48 PM
Turbo6TA's Avatar
Turbo6TA
Jeeeze ... now I feel that I might not have enough sub in my coupe after I get this system together.
I installed a JL Audio 8" sub powered by a 5-channel Arc Audio XDi805 (240 watts RMS into the sub)
Old Nov 17, 2011 | 05:01 PM
Thrash's Avatar
Thrash
Realize I am going with twin 10's because of the blockage issues in a vert with the top up and especially when top is down. In my coupe the single sub seemed fine, but at the expense of the space a second would have been better.
You might be fine in a coupe, but that is a really small sub. I'm also using the XDi805 for the subs, so adding the 2nd 4 ohm sub makes it a 2-ohm load and 200 watts x 2 power (printed spec is 400w x 1 at 2 ohm), right?
Old Nov 17, 2011 | 06:10 PM
NYC6's Avatar
NYC6
Which JL 8" driver are you giving 240w rms?
