Sponsored by: Innova
C6 cargo area ground location
Old Dec 9, 2011 | 10:07 PM
cstapp99's Avatar
cstapp99
Default C6 cargo area ground location
Preparing to install a Bazooka tube in the rear of my c6. I have all of the wiring installed but have not done the ground yet. Could someone recommend a good ground location in the cargo area? Thanks
Old Dec 9, 2011 | 10:41 PM
WAwatchnut's Avatar
WAwatchnut
Is the tube going in the front or back of the cargo area? I don't know of a good ground in the back - not sure where the Z battery is grounded to. But towards the front, there is a factory grounding point at the base of the passenger side B pillar. (halo).
Old Dec 9, 2011 | 11:29 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
There's also a ground point on the top of the rear bumper/frame.
Pull the outer passenger side tail light and look straight down. It has a plastic cable holder stuck on the exposed thread, but the post is long enough to easily mount an additional ring terminal/cable.
Of course you have the problem of penetrating the rear plastic trunk-tub, but it's very close if you are installing your powered speaker back there.
Old Dec 10, 2011 | 09:37 AM
cstapp99's Avatar
cstapp99
Thanks guys. The sub is going at the back of the cargo area where the cargo net would be.
Old Dec 10, 2011 | 05:12 PM
cstapp99's Avatar
cstapp99
This is the one I used. Thanks for the perfect description.
This forum and it's members are simply awesome.
To C6 cargo area ground location
