Sponsored by: Innova
C4 stereo help
Old Feb 21, 2012 | 06:40 PM
LD85's Avatar
LD85
Default C4 stereo help
My stereo sounds like crap, just not very clear at all, and I honestly just don't know what to do, you only have the front speakers in a C4 and my two 6.5" round speakers just suck,
What can I do to improve my setup? I am tempted to put some 6x9's in the rear and leave the 6.5's in the front and buying a separate 10" sub to sit in the hatch area
Head unit = Eclipse CD4000
Rear Speakers
Two 2-8" JBL subs with 2 x 150 watt amp
Front Speakers
Focal 165V1 with Phoenix Gold 2x75
Old Feb 22, 2012 | 03:31 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
http://www.diymobileaudio.com/forum/...eter-pods.html
Larry,
Give this a try. It rasies the sound stage, which is now blocked by your legs. I did this in my car, it made a real difference.
Randy
Old Feb 22, 2012 | 04:14 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You only have front speakers in an 85? My 90 had 4. I put 6x9 in the back and 5.25 in the front doors and it would blast you out of it with no amp or sub.
I do think the eclipse is a good HU. Good choice. I know a lot of people put subs in these things, but I've spoken to more than one audio person and they said subs were overkill in these cars with 6x9 speakers. Also said 4 speakers was overkill. But with 6.5 speakers I can see the need for a sub. I'm going to put in a sub or 6x9 Focals in my partion in my FRC. can't decide which would be better. However with this said I know there are some people really serious about this so it comes down to personal choice.
Old Feb 22, 2012 | 06:43 PM
Kale's Avatar
Kale
In my 86, I hung my tweeters in pods under the dash pad. Worked real well.
Old Feb 22, 2012 | 08:45 PM
LD85's Avatar
LD85
I have decided to by two more Focal 6.5 or two more 6x9 speakers for my rear, that will give me two from Focals and two in the rear,
Then I am going to buy one 10" rear or use my two 8" subs as well.
I am sure that this will make a substantial improvement, and I don't care if the voice part is in front or back of me.
Should I match my front Focal two way 6.5 diameter round speakers with the same model number in the rear or buy 6x9s for the rear?
I will buy a decent quality 4x75 or 4x100 amp to replace the 2x75 amp, and the nI wont take up any more space and will still have just two amps
or do they make a 6 channel amp?
Old Feb 23, 2012 | 05:35 PM
RandyJ75's Avatar
RandyJ75
Focal makes 6 x 9 2 way speakers, give them a look. You can buy a 6 channel amp, or a five channel will work if you go w/ one 10" sub.
You could also drop a line to Dennis at DD Mods, He can help you w/ what ever you need.
Old Feb 24, 2012 | 10:14 AM
LD85's Avatar
LD85
I'm gonna build a custom box for the two 8" subs,, 6" tall, by 16" by 10" for a .34 cu/ft sealed
and put two Focal 6.5"s in the rear, leave the 2 Focal's in the door and use a 4 x 100 Alpine PDXF-4
I'll run the two 8" subs, w/bridged mono 400 watts
Old Feb 24, 2012 | 10:17 AM
LD85's Avatar
LD85
Larry,
Randy
I could put tweeters in the dash plates if that would help
Old Feb 25, 2012 | 12:15 PM
RandyJ75's Avatar
RandyJ75
I think that will work great Larry, You'll be very happy w/ the results.
Good Luck,
Randy
Old Feb 25, 2012 | 09:02 PM
LD85's Avatar
LD85
Good Luck,
Randy
Cool, I ordered a pair of tweeters,, so the setup will be two 6.5" 2-way in door, two 6.5" 2-way in rear and two 8" sub, 2-inverted dome tweeters on top of dash/pillar area.
Old Feb 26, 2012 | 12:07 PM
RetiredSFC 97
I think that's your best bet. With subs you don't need the 6x9's, and the 6.5 with subs will give you a better sound.
6x9's are best suited for those who skip the subs.
Old Feb 28, 2012 | 11:14 PM
LD85's Avatar
LD85
Tonight I mocked up the rear 6.5's with the two subs in the storage area,,, 4 Focals , same model,,, 1000% better BUT,, I still need to add the tweeters I ordered to the top of the dash area/pillar when they arrive, that will balance out the front and rear since the fronts are pointing at my knees, right now it sounds great but the tweeters in the rear are not balanced, hence the need for the front tweeters.
I'm gonna pump 400 watts mono to the subs and the 4 / 6.5's will have 4x100
I am pleasantly pleased with the simple effort, I need to make boxes for the subs / storage compartments, then its good to go.
Old Feb 29, 2012 | 09:51 AM
RandyJ75's Avatar
RandyJ75
Take some pictures Larry, we all love pictures.
Old Mar 1, 2012 | 12:42 PM
LD85's Avatar
LD85
I'll post pics this weekend when I'm doene.
Here are the Tweets I bought
Old Mar 3, 2012 | 10:10 PM
LD85's Avatar
LD85
Wow, they sucked, they are going back, I could not even hear them
Old Mar 3, 2012 | 10:13 PM
LD85's Avatar
LD85
Larry,
Randy
Can you recommend a pair of tweets to use?
Old Mar 4, 2012 | 03:40 PM
LD85's Avatar
LD85
The Tweets they sent me were an open box and where defective They are sending me a new set.
Can I run these off my head unit Eclipse CD4000 = 50 watts max
To C4 stereo help
Old Mar 4, 2012 | 07:28 PM
CorvetteArchives's Avatar
CorvetteArchives
I added 4x6 infinity kappas (462.9cfp) to the stock dash openings normally used for nonBose Vettes.
I had just replaced the Blose with 6x9's in the rear and 4" in the door (no cutting required) but they were still missing that fuller sound that the Dash speakers completely solved.
Old Mar 4, 2012 | 08:18 PM
LD85's Avatar
LD85
Thanks, that might be my next move, a new set of tweeters is on the way so if that does not pan out, then dash speakers might be next.
Old Mar 4, 2012 | 11:46 PM
RandyJ75's Avatar
RandyJ75
Larry,
Because of the extra space you have, you can use some large format tweeters. Take a look over at Madisound.com. If you would like a used set of crossovers, I believe I have a set somewhere in my house. I will send them to you for the cost of shipping; that way your tweeters will only reproduce the highs the are meant to. Just hooking them up to you HU will make them try to play the full range of the musical spectrum, not what you want.
Send me a PM if I can help.
Randy
