Sponsored by: Innova
Ground wire
Old Sep 18, 2012 | 02:35 PM
lhinaz71's Avatar
lhinaz71
Default Ground wire
I'm replacing the factory Bose in my 88 with an aftermarket hu and amp. The amp is an alpine ktp-445u designed to run on the same wiring/fuse as the hu. The amp directions indicate that you should connect the black wire from the amp directly to the car.
The factory wiring harness also has a black ground wire.
Would I be better off connecting the ground directly to the car or using the ground wire on the harness?
Old Sep 18, 2012 | 04:23 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
will get better results with a solid frame ground
