Sponsored by: Innova
Back Up Camera While Driving?
Old Mar 25, 2013 | 08:33 PM
bartsky's Avatar
bartsky
Default Back Up Camera While Driving?
Can you wire your back up camera to where you can view it even driving forward?
Old Mar 25, 2013 | 08:47 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
yes as long as you have it wires to switched power and not to pos and neg on reverse lights
Old Mar 25, 2013 | 08:51 PM
bartsky's Avatar
bartsky
So it will only come on when I select it as a source, and not when I put it in reverse?
Old Mar 25, 2013 | 08:59 PM
0Double D Mods
Former Vendor
no it will come on when putting in reverse too when the reverse wire is connected
what I mean is most people will connect the power and ground to power and ground on the reverse lights
If you do this the camera will only have power when in reverse so no way you can turn it on while in motion
So if you connect to say the power and ground in radio harness(red and black) it will have power at all times. So when you select camera on the screen it will switch to the camera
Old Mar 25, 2013 | 09:16 PM
bartsky's Avatar
bartsky
Ok cool! Thanks again...
Old Mar 29, 2013 | 09:27 AM
ch47d1sg's Avatar
ch47d1sg
I have two cameras on mine, front and back. Power is switched power from the ncm bus. I can select my front cam at will
Old Mar 31, 2013 | 07:58 PM
bartsky's Avatar
bartsky
Well I just went out and changed the power wire from the camera to the radio fuse. They had it ran to the reverse lamp fuse. Now the camera comes on when I want with the push of a button...
Will this shorten the cameras life since it will be powered all the time my radio is on? Also, I guess it was ok to run the power wire for the camera to the radio fuse? Thanks for any help...
Old Mar 31, 2013 | 08:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Needs to be ran to a switched source not constant or battery will be dead
Old Mar 31, 2013 | 08:27 PM
bartsky's Avatar
bartsky
Is the radio fuse in my C6 a constant? With the radio, and car off, the camera will still draw current hooked to the radio fuse?
Old Mar 31, 2013 | 08:29 PM
bartsky's Avatar
bartsky
Should I run the camera power wire to the fuse in the floorboard labeled ignition Greg?
Old Mar 31, 2013 | 08:33 PM
pentavolvo's Avatar
pentavolvo
Test it with a multimeter.
Old Mar 31, 2013 | 08:57 PM
bartsky's Avatar
bartsky
With the car, and radio off, will the camera still be powered? I don't have a meter here.
To Back Up Camera While Driving?
