Sponsored by: Innova
Elec interference
Old May 31, 2013 | 07:31 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Default Elec interference
When i adjust my seat or the pass seat the radio in AM mode goes dead for a second not the power just the sound more like shorting out,
it does this only while initially touching the switch then the sound comes back.Something's not grounding properly i guess causing this staticky short I'll call it. Any ideas about this gremlin?
TIA Rob
Old May 31, 2013 | 08:03 PM
markcz's Avatar
markcz
Car info?
Old May 31, 2013 | 11:16 PM
Rob 99's Avatar
Rob 99
Sorry i should know better after all these years here.
2013 4LT Factory Nav/Radio
Old Jun 1, 2013 | 10:45 AM
markcz's Avatar
markcz
Watch the DIC, is there a noticeable voltage drop when you hit the seat button? If yes, the antenna module may just not be able to maintain a proper level while it dips.
If that's not it, could be just about anything. At one point in my '07 the entire dash would flash in sync with my turn signals, that was caused by a melted LED turn signal bulb that was causing voltage to flow wherever it could.
Old Jun 1, 2013 | 09:17 PM
Rob 99's Avatar
Rob 99
Well i tried the test you suggested and couldn't get the issue to repeat itself of course... i'll try again each time i use the car
(hey GM im testing the electrical circuit loading and resistance to atmospheric interference and stratospheric resistance for modulation for you) (totally made up of course)
Should it repeat i'll make sure to watch the volt readout, although while testing earlier it didn't move really 13.9-14.0 idle, i activated the seat switch & volts stayed in that range and no static on the AM band.
So whatever it is seems to be intermittent at this time, and really unless it affects somthing else or spreads into a bigger elec prob im going to move on and just consider it a wonder of modern marvel
Thanks for your help
Rob.
update: used the car last nite and did notice the farther i got away from NYC where the radio signal is broadcast from the weaker the reception got and pressing the seat switch caused the sound to go dead for a second for each time pressed and no change on the volt gauge reading.
To Elec interference
