Sponsored by: Innova
iPad Installation Volume Question
Old Aug 2, 2013 | 03:21 PM
th3pip3r's Avatar
th3pip3r
Cruising
Default iPad Installation Volume Question
Awhile back I did an iPad install:
I have an iPad dock in the dash to provide power to the iPad and get the line out audio signal. From the line out, it goes through a filter and a volume control. The volume control can be seen here:
http://www.sonicelectronix.com/item_...te-RSW250.html
After the volume control, it is connected to the factory bose amp through the harness that used to be connected to the navigation.
My question is does anyone know a good way to boost the volume? It is not bad with the windows up and top on, but otherwise it is hard to hear. Does the bose amp have any volume control that I need to change? If not, is there a way to boost the signal to the amp?
Old Aug 2, 2013 | 05:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
http://www.ebay.com/itm/NEW-PAC-LD-10-ADJUSTABLE-AUDIO-RCA-LINE-DRIVER-SIGNAL-BOOSTER-10X-AMPLIFICATION-/360395799066?pt=US_Car_Audio_Video_Connectors_Terminals&hash=item53e9437a1a
This should do it
Old Aug 12, 2013 | 07:52 PM
th3pip3r's Avatar
th3pip3r
Cruising
Worked great, thanks!
To iPad Installation Volume Question
