Sponsored by: Innova
'86 Radio install
Old Jan 29, 2014 | 04:03 PM
ALG's Avatar
ALG
Default '86 Radio install
Has anyone installed a double din radio into a '86 vert?
I am wanting to put one in for the GPS, Bluetooth, and other.
I understand that i will have to cut the bezel. Just wondering what other issues I will run into. All the speakers have already been changed. I currently have a single din in it.
Thanks for any help and info you might have.
Old Jan 29, 2014 | 04:15 PM
Dt86's Avatar
Dt86
I believe you also have to customize your radio chassis bracket. What head unit are you going with? I'd like to do this in the future. I've installed a similar system in my tacoma before. Only issues with gps and Bluetooth are finding the best locations to mount the gps antenna and microphone. There's some good gps antennas that mount right in your dash if you find a good spot. I mounted the mic at the rear view mirror.
Old Feb 4, 2014 | 09:32 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I replaced, and all you need to get brackets and faceplate for your radio.
To '86 Radio install
