Sponsored by: Innova
Memorial Day Progress
Old May 27, 2014 | 10:19 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Memorial Day Progress
So I made a lot of progress over memorial day weekend.
my 1-line drawing:
The Sac City Corvette big 3 DOES work on a C6. You just need a C5 battery, which fits.... barely. Now you know.
The old battery coming out:
big 3 at the alternator:
Big 3 engine ground
http://s185.photobucket.com/user/gur...ml?sort=3&o=22
The c5 battery installed:
The rear driver side:
The rear passenger side:
Ballz (my wife is such a joker):
Passenger side door (without speaker):
A whole mess of wire waiting to be dressed:
Driver side door (without speaker):
http://s185.photobucket.com/user/gur...ml?sort=3&o=11
Dash in progress (mock up):
Passenger side door panel (with tweeter):
Driver side door panel (with Tweeter):
Parts:
Amp mounted. I used some big fender washers to compress against the carpet with the corner mounting holes on the amp. This way the pressure was off the bolts and I wouldn't have to make permanent modifications to the car:
The PAC adapter, and the head unit wiring harnesses turned into a single harness.
The amp wired and dressed:
The dash back together:
Later today I will get the door speakers in and put the battery back in and see if everything turns on. Which would be awesome!
The remaining task will be to get the sub in the sub box and test that. Then reassemble the rest of the interior.
Old May 27, 2014 | 01:42 PM
Guru_4_hire
Cruise-In V Veteran
OK so everything turned on, nothing burst into flames, no warnings, my traction control button still works.
Audio sounds good, but needs to be tuned, seems like something is taking the bass out. Of course it could probably be because its set up for a sub and I haven't put the sub in yet.
Old May 27, 2014 | 02:16 PM
Guru_4_hire
Cruise-In V Veteran
Got the sub in. Holy crap. Its like a massage chair.
The JL sub and the Alpine amp hit hard.
No dimming with the sub either, at least not that I can see. Night will be a better test.
Its like a dance club....
So awesome.
Old May 27, 2014 | 03:53 PM
Guru_4_hire
Cruise-In V Veteran
So while hanging out in the driveway, I noticed that with the engine fan running the voltage drops significantly to 13+-.5
I think I may need to upgrade the alternator. Any thoughts on this?
Once I get the interior back together I will drive around and see what happens. It was 14.5 the other day, I wonder if its just the engine fan or if there is something else going on.
Old May 27, 2014 | 05:05 PM
markcz's Avatar
markcz
I can do your install half drunk and with my eyes closed, but I would NEVER put the dash back together without testing everything first
That's 100% normal with the engine at idle, your voltage is actually a bit higher than I would have guessed.
I put in a DC Power 270 Amp 13968-270-XP, and it works GREAT, but it is way overkill. Normal voltage is 14.8. At idle, AC running, all lights on, heated seats on red, and stereo cranked as high as it will go.... 14.7v
I put LED switchback bulbs in for my front signals. Several sets blew and one melted before I figured out that I was cooking them with too much voltage, so I had to splice in some resistors to drop the signal voltage down to 12v
All that being said, if you do put in a high output alternator, I highly recommend the DC Power. It puts out more juice at idle than the oem could at max output. One of these days I'm going to do some research to see if any of the custom laptop tuner programs can change the voltage setpoint, if it can I may just have to get one so I can drop mine down to 13ish.
Old May 27, 2014 | 06:31 PM
Guru_4_hire
Cruise-In V Veteran
Thanks. If its normal than cool!
Done! and with only 1 screw I don't know where it came from. Seems like a win to me.
Old May 28, 2014 | 08:39 AM
Guru_4_hire
Cruise-In V Veteran
A few more pictures:
Old May 28, 2014 | 11:22 AM
Mike Beck's Avatar
Mike Beck
Never fails! After having so much stuff torn-apart, there is always one or two left.............
To Memorial Day Progress
