Sponsored by: Innova
2008 C6 Nav not saving time settings
Old Jun 1, 2014 | 09:02 PM
discypl's Avatar
discypl
Default 2008 C6 Nav not saving time settings
Hi all - my 2008 C6 with factory nav is not capable of saving the time settings. When I start the car, the time is always set to EST (I am in PST). I can manually change the setting to PST and Daylight Savings, but the car forgets when I switch it off. It has no trouble remembering the radio stations I've programmed, though, so I don't believe it's the battery. The GPS doesn't have any issues locating me or setting the minutes properly, so I don't believe it's the GPS thinking I'm in another time zone. Yes, I am using the same key (key 1) each time and there's no indication it isn't recognizing the key
As a side note, the nav also does not remember previous destinations.
Is this a known issue and I should just swap it, or is there a quick fix? Thanks!
