Sponsored by: Innova
Front Camera
Old Jun 20, 2015 | 02:46 PM
red 08 ca.'s Avatar
red 08 ca.
Default Front Camera
Has anyone connected power for front camera to the DRL since they only come on when car is running. Currently I have them connected to my fog lights which also requires headlights as well and having to remember to turn on and off.
Any help or other suggestions would be appreciated.
Old Jun 20, 2015 | 03:52 PM
markcz's Avatar
markcz
What year is car?
There are several places you can tap a switched power source
Old Jun 20, 2015 | 04:34 PM
red 08 ca.'s Avatar
red 08 ca.
Originally Posted by markcz
What year is car?
2008 base
Old Jun 21, 2015 | 01:37 PM
markcz's Avatar
markcz
Heated seat or wiper fuses are normal switched power.
To use RAP signal:
Audio prints are HERE. Look at schematic 1/10. Third wire from the right is the one to use. It connects to the oem amp at pin A3 of amp plug C2. The 0.35 under the WH indicates that it's a 22 gauge wire. The circuit number is 1487.
Look at plug 2/15. It's shown as a 24 pin gray plug.
The oem amp is the silver box on far left side of the footwell area. Find the 24 pin gray plug and use plug print to verify you use the right wire, but it should be the only white one on that plug.
To Front Camera
