HU crossovers should already be set. Front HPF around 100, sub LPF around 100, but you can adjust them up/down depending on how your system sounds to you.
If it's the EQ you're asking about, just pick the preset that matches your most common type of music.
let's say I adjust the h/U from 100 to 125 don't I have to adjust that on the Amp ? Also what about adjusting the slope? Sorry so many questions!
I was also doing some reading and one thing I read was don't use the LP on the head unit and the LP on the amp say for the sub....can cause phasing problems keep one of them off don't keep both on I don't know how true that is
Yeah-that works. The hell with the stereo.
Time alignment. Adjust the distance so the sound hits you at the same time relative to your distance from the speakers.
Before you do anything, play with set-up first. YOu may be able to tune some of that brightness out
yes I will. Just want a backup plan. I think I would go with morel!! I can't wait to work the bugs out of this system it sounds so clean now!! And to think I still have more power if I want it!!!! And let me say the front stage is everything on a high end system!
We gotta get you a blower-then you'll be talking some music!!
Yeah that would be nice with heads and a cam tune for e85. I had a Whipple 2.9 on my 04 cobra e85 tune made 650 to the wheels easily that was a fun car.
Are tweeters supposed to sound Clear when playing? My Focals sound like the sound is from a distance if that makes sense? And very high picthed! Not clear at all. Not happy with Focal tweeters. So I will spend $250 on some new ones. I just want to do this once...does these also have to be 4 ohms?
