Sponsored by: Innova
Is capacitor needed???
Old Dec 12, 2016 | 11:56 PM
Pittcorvette's Avatar
Pittcorvette
Default Is capacitor needed???
Ok, I have a Kenwood ddx690 with a Kenwood 1000 watt amp for a 10 jl audio corner sub. I have Bern noticing that my lights have been flickering a bit when the bass kicks. I am also looking into replacing my car battery. Should I use a capacitor for my set up. I have heard cons about capacitors draining batteries. I really need the communities help regarding my issues. Thank you in advance.
Old Dec 13, 2016 | 12:43 PM
Curt D's Avatar
Curt D
I would just up the alternator.
I had a cap in my truck for 10 years without battery issues. It didn't cure my dimming so I added a 200A alternator which eliminated it. That was 1000w from a/b amps with 600 to a JL 8w7.
The vette will have about 1900w when I get it back. I will add a 170 or larger Mechman alternator...no cap. My JL 10w3 is only getting 640w. The front 3-ways are getting 640w a side via Mosconi AS amps.
Old Dec 13, 2016 | 05:16 PM
Eff A Ford's Avatar
Eff A Ford
Do the "Big 3 Upgrade" first and see what happens.
Old Dec 13, 2016 | 05:44 PM
02BlownZ06's Avatar
02BlownZ06
Yup! Big 3 upgrade for sure first! It is relatively inexpensive, maybe $150 or so and may eliminate the problem entirely.
Old Dec 13, 2016 | 05:47 PM
02BlownZ06's Avatar
02BlownZ06
Check out this thread: https://www.corvetteforum.com/forums...e-big-3-a.html
Old Dec 14, 2016 | 01:02 PM
Homer3D's Avatar
Homer3D
Yes, I too was going to suggest doing the Big 3 upgrade...however you can do it a lot less than $150. Google "Big 3" and you can find kits for $40-$50.
That one from SacCityCorvettes looks nice since it is pre-cut and pre-wired, but if you don't mind doing your own cutting/wiring, you can save money.
To Is capacitor needed???
