Sponsored by: Innova
Parking Switch Wire
Old Jun 11, 2017 | 05:44 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Parking Switch Wire
Why would I need to connect the Parking Switch Wire on a Double Din install ???
Jim
Old Jun 11, 2017 | 08:10 PM
TorchRedFred's Avatar
TorchRedFred
When your car is parked, it unlocks certain features that you can't use (or are locked) while in motion. For instance, like watching videos. You can't do it while driving. There are ways to by-pass this feature to make all options available at all times. You can research your model and "by-pass parking brake" and you should get some options. I know my Pioneer Nex has a built in secret menu to disable it so I didn't worry about it until after it was installed.
Old Jun 11, 2017 | 08:51 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Thanks I'll look that up...Also, I lived in Cedar Knolls when I worked for AT&T funny how small the world is and I bought my 99 C5 from a guy who lived down the road from the HQ Building for AT&T in Morris Couunty.
Jim
Old Jun 11, 2017 | 09:23 PM
TorchRedFred
Jim
The world sure is small. I drive through Cedar Knolls everyday on my way to work. Usually Rt10 east to 287S.
Old Jun 11, 2017 | 09:35 PM
TorchRedFred
Also you can check youtube for how to videos. Just type in for example "kenwood parking bypass". I know there is a relay you can purchase to bypass it.
Old Jun 11, 2017 | 10:53 PM
TheProsecutor's Avatar
TheProsecutor
Just ground the green wire.
Old Jun 12, 2017 | 12:11 AM
TorchRedFred
It depends on the head unit. I think that just grounding the green wire works on some brands and head units but not on all. I had read somewhere when I was doing my install that just grounding the green wire wouldn't work on my Pioneer. If it's a Kenwood, you may have better luck but I'm not sure if it's the same with all Kenwood models. Found this youtube video for Kenwoods,
Old Jun 12, 2017 | 09:43 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
kenwood does not need a relay
ground parking brake wire is all
Old Jun 12, 2017 | 09:44 AM
0Double D Mods
Former Vendor
It depends on the head unit. I think that just grounding the green wire works on some brands and head units but not on all. I had read somewhere when I was doing my install that just grounding the green wire wouldn't work on my Pioneer. If it's a Kenwood, you may have better luck but I'm not sure if it's the same with all Kenwood models. Found this youtube video for Kenwoods, https://www.youtube.com/watch?v=O_VgAq4MR-E
NEX models with NAV you can ground the parking brake wire on Pioneer. YOu just have to finish the rest on the touch screen
Old Jun 12, 2017 | 11:18 AM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Reverse For Backup Camera
Dennis in my haste to install the backup camera I forgot to run the power wire for the reverse lead on my JVC HU. I have finished all the insulation and put all the carpeting back and I could run a wire from the backup lights to the radio but is there a closer connection inside the car ?
Thanks,
Jim
Old Jun 12, 2017 | 11:35 AM
0Double D Mods
Former Vendor
Thanks,
Jim
nope
sorry
Old Jun 12, 2017 | 04:03 PM
TorchRedFred
Thanks,
Jim
Hey Jim, I'm not sure I understand, but when I installed my camera I ran a video wire to the camera and then power wires from the camera to the reverse lights. That's it, I didn't run any power wires back to the radio.
Old Jun 12, 2017 | 09:41 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Power Wire
Torch,
I ran the camera power to the reverse bulb connection and the RCA plug back to the HU, but on the back of the JVC HU there is a wire for reverse which powers the video I believe....Dennis may chime in here but I thought it better to take the carpeting apart then to figure out where the hell the wire is in the engine compartment fuse panel.
Here's hoping everything will work still trying to figure out how to cut out the shelf in the radio/AC mount.
JIm
Old Jun 12, 2017 | 09:59 PM
TorchRedFred
Torch,
JIm
Jim, we all have that wire. It's not for power. It gets attached to the green wire on the wiring harness. That just sends a signal to the radio to change the input to the camera when you put it in reverse. What harness did you get? I used the Pac Audio RP5-GM11. Read Dennis's instructions, he mentions that you have to connect that wire yourself. I didn't use Dennis, but I saw his install thread.
Old Jun 12, 2017 | 10:21 PM
TorchRedFred
Here is a picture,
To Parking Switch Wire
