Opinion on Subs
Problem... the existing subs I have, JL Audio 8W7s, are positively massive and require a huge box, nearly 1CF and at least 8" deep to go with the 10" square... so huge...
I am looking at a pair of JL Audio 10TW3-D4 or one JL Audio 12TW3-D4.
Doing the math, I figure I can build a sub box that is the width of the cabin, about 6" high and 14" deep, with space for the amps between the subs. And still have clearance for the hard top, or, luggage.
I have a Pioneer 600 watt 1 ohm stable mono amp, so power is not a problem.
thoughts?
the 8w7 is a great driver. 1cu/ft is not a large box. if you want output it takes volume. if you don't an 8w3v3 plays well in .4-.45cu/ft and only requires 200w
i'm not a fan of shallow subs
a single 8w7 in a qtc 707 alignment and 600w will provide ample bass in a coupe. you don't need "subs" if space is a concern. you could fit a 10w6v3 in a box as small as .75cuft and not have the Q climb too badly or limit output. qtc 707 happens at .91cuft on a 10w6v3
in general a smaller driver in a larger box will sound better than a larger driver in a smaller box
I am not sure what pioneer amp you have but if you say it is 600w @ 1 ohm then I would assume it is 300w @ 2 ohms. With that power rating, you can pick up the JL stealth box that is preloaded with the JL 10W1v3-2 which is a 300w 2 ohm sub. I have the JL stealth box in my C6. Sounds good and doesn’t take much space away from the trunk and you can still store the top.
I have no way of testing it to confirm the accuracy of said amp, it does work well and seems to have the *****.
I was thinking of the shallow mount subs because, well, it's new and perhaps worth trying. Sure, it defies a lot of the expected norms, but gee, so does a lot of modern tech.
I do like the idea of the stealth box... looks like a nice fit.
I think I will see what I can do to fit the 8W7's. Those are intense...
thanks for the feedback, I will give you all an update shortly.
Over all the 10tw3 was a great sub but it def won't replace your current ones. I actually just finished up installing the JL 13tw5 in my c6 and it's honestly my favorite sub to date
EDM, rap, hip hop, classical, country, all these can dip into the 20s
imo a rock music system is a bit of a different setup. you can often operate the subs in smaller boxes since a higher Q punchy type bass is actually prefered by a lot of people
I can't say I have seen country go down into the 20s... Classical can. So can some prog rock - Pink Floyd, Genesis, Yes - they play with synths and bass pedals.
Organ, particularly pipe organs, can go way down low.
I am going to do some measuring... see what I can make fit. I have some ideas and I want to tinker with.
That or I will go with a shallow sub.
i was just thinking off the top of my head. 98% of what i listen to is house. trance, edm, like a trip to ibiza rolling down the street.
getting a car stereo to do classical right would be something. you have this HUGE dynamic range and so many reflections which alter the sound of the instruments.
Agree with the classical comments. That is some of the most demanding stuff to reproduce accurately.
