Sponsored by: Innova
Stealth Box and Tire Sensor
Old Dec 19, 2017 | 03:15 PM
Big Mo's Avatar
Big Mo
6th Gear
Default Stealth Box and Tire Sensor
I have a 2007 Coup and have been giving a lot of thought to purchasing and installing the JL audio stealth box. After reading reviews, I discovered one person that claimed that after the install of the box, it caused his drivers side rear tire sensor to remain on. Has anyone else experienced such an issue?
Old Dec 21, 2017 | 05:33 PM
Homer3D's Avatar
Homer3D
I had a stealth box in my 2005 C6 and in my current 2013 GS. Never had an issue with the TPMS.
Old Dec 28, 2017 | 10:02 AM
Big Mo's Avatar
Big Mo
6th Gear
Thanks for your reply. Are you pleased with the performance and sound of the stealth box?
Old Dec 28, 2017 | 12:40 PM
Homer3D's Avatar
Homer3D
I liked the original stealthbox that was in my 2005. That one was loaded with a 10W3v2. The current version is loaded with a 10W1v3.
Not to say the current stealthbox is bad but I liked the bass response and power handling of the 10W3 more.
Old Dec 31, 2017 | 10:40 PM
geezel's Avatar
geezel
I just installed the latest version Stealthbox in my 07 Z06 and love it. No issues with TP sensors.
Old Jan 1, 2018 | 01:40 AM
Big Mo's Avatar
Big Mo
6th Gear
Outstanding. Thanks for your reply. How does it sound? And any recommendation on an amp? I’m sure I will be purchasing the JL Audio Steakth Box but undecided about an amp.
Old Jan 1, 2018 | 02:52 PM
geezel's Avatar
geezel
The Stealthbox is plenty for the small Corvette cockpit. Any Class D mono amp will do. No need to spend a fortune on one IMO.
Old Jan 3, 2018 | 12:20 PM
Homer3D's Avatar
Homer3D
The sub is a 10W1v3-2 which has a power handing rating of 300w @ 2 ohms. So you are going to want to get an amp that produces at least 250w x 1 @ 2 ohms. The sub can actually handle more. I am running 500w into my stealth box with no issues.
Old Jan 3, 2018 | 06:07 PM
Big Mo's Avatar
Big Mo
6th Gear
I wanted To run the Fosgate R500x1D but the local shop keeps pushing the JL Audio MX 300 because of its size. I’m so undecided my heads gonna explode.
Old Jan 3, 2018 | 07:17 PM
Homer3D's Avatar
Homer3D
The JL MX300/1 is their marine line of amps so they are water resistant. Not sure if that is a benefit to you or not. I am using JL’s RD line. Very good amp. Clean power. The Rockford Fosgate R500X1D is their “Prime” lineup which is their more budget friendly line of products. I think it is a decent amp, especially for the price. I have not run this amp myself in the real world (only experienced in an audio shop) so I can't speak to its performance. But Rockford tends to under rate their amps so it most likely produces more than 500w @ 2 ohms.
Old Jan 3, 2018 | 08:11 PM
Big Mo's Avatar
Big Mo
6th Gear
They recommended the MX because of its conceal ability. But I am thinking I would prefer to go with an exposed amp that is a proven dependable amp that will hit the lows over an amp that is concealed but leaving me disappointed.
Old Jan 5, 2018 | 09:37 AM
geezel's Avatar
geezel
I'm running the Rockford R500X1D and am happy with it.
Old Jan 5, 2018 | 09:56 AM
Big Mo's Avatar
Big Mo
6th Gear
Where do you have yours mounted? I'm 6'5 and my wife's a bit tall also, so behind he seat is not an option for us.
Old Jan 5, 2018 | 10:24 AM
geezel's Avatar
geezel
Behind the passenger seat. Plenty of room there.
To Stealth Box and Tire Sensor
