replace 08 Nav to Kenwood without nav
Help would be great. Pictures would be great. Recommendations will be great.
I have time since this unit doesn't come out until march sometime.
yea I was thinking something like that but in the place of my cig lighter. so its easily able to be plugged in as a driver or a passenger. minus the HDMI. I don't need that. Dual USB is what im looking for.
Here's an Amazon link to what I bought:
Here's an Amazon link to what I bought: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I received the HU as a Xmas gift from my family, so I can't tell you where they got it. If I had to venture a guess, I'd say Best Buy, but not certain.
For the dash kit & PAC unit, I went to Crutchfield. Dash kit is the standard Metra 95-3304 everybody recommends ( Link - https://www.crutchfield.com/p_120953...t.html?tp=3121 ). PAC unit is the RP5-GM11 ( https://www.crutchfield.com/p_541RP5...e.html?tp=3486 ). Also got a "Scratch & Dent" Sirius/XM receiver, but it was DOA so I didn't install.
Re: Install -- It's pretty straightforward, thanks to all the excellent guides available here on the forum. Wiring the PAC harness is the most tedious, but not difficult as long as you take your time and double-check your work against the wiring diagram as you go. I would recommend doing the harness work a day or two prior to the install, when your head is clear. There's a fair number of connections that need to be made, and I can see where you could make a mistake if you aren't focused on the work.
The actual install in the car is not difficult at all. Read through the forum guides a few times prior to become familiar with the process. I had an iPad with me to double check a couple things during the install. I had my son as a helper, which made things go easier than flying solo on the project. As for the USB port cable, I ran it from the back of the HU in the dash under the center console trim to the center console. Plenty of room and a clean fit.
Good luck & have fun!
