Sponsored by: Innova
10 beeps when pushing any internal button after double din install
Old Apr 23, 2018 | 07:42 AM
Narddog's Avatar
Narddog
Default 10 beeps when pushing any internal button after double din install
This is one of those problems that's more annoying than anything. Everything still works except the steering wheel controls (didn't install the adapter since I never use them to begin with) but my issue is that whenever I press anything (trip button, unlock button on door, instead of 1 beep like OEM, I get 10 beeps. It's super annoying. Anyone else ever experience this after install and how did you fix it?
This is what I installed. The issue is the CRUX unit I believe, but not sure what would cause that.
CRUX SOCGM17B
https://www.sonicelectronix.com/item...ed-System.html
Kenwood DDX574BH Radio
Metra40GM antenna adapter
Old Apr 23, 2018 | 10:04 AM
TorchRedFred's Avatar
TorchRedFred
I know I had seen this before. I used the search tool and found the thread. Seems like a Crux thing. You may want to try reaching out to the OP to know for sure.
https://www.corvetteforum.com/forums...ton-press.html
Old Apr 23, 2018 | 10:18 AM
madsonp's Avatar
madsonp
Like the saying goes, you get what you pay for. You should have went with the PAC harness adapter. https://www.crutchfield.com/p_541RP5...Interface.html
Old Apr 23, 2018 | 12:34 PM
bartsky's Avatar
bartsky
Yep PAC....
Old Apr 25, 2018 | 07:28 AM
Narddog's Avatar
Narddog
Thanks for the info guys!
To 10 beeps when pushing any internal button after double din install
