I have no clue about audio systems, so here is my question. What type is the center dash speaker for the Bose system (2way, 3way, woofer, tweeter). I want a similar speaker, but I want it as a flush mount
with a grill to cover it. I'm thinking of adding the similar speaker to the "B" column in the center portion.
Thanks for any info.
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
OEM speaker is a 3.5" 4ohm speaker. If you are looking for an aftermarket 3.5" speaker, most are 2 way, which means it has a separate tweeter built in.
Picture of a 2-way 3.5" speaker. You can see the tweeter in the center.
