Sponsored by: Innova
Unplug/remove door subs with trunk sub?
Old Mar 16, 2021 | 10:56 AM
QuiksilvrZ's Avatar
QuiksilvrZ
Default Unplug/remove door subs with trunk sub?
I am about to be installing a single 10" sub in the center trunk well of my C5Z. I have no immediate plans to upgrade any of the rest of the Bose system at this point in time. Should I disconnect the door subs to keep them from clipping? I can hear them doing so as is when I turn up the volume. Since I'll have the sub in the trunk, would I be missing anything if I just ran with the twiddlers for now? I already know most of you will say I should rip out the entire Bose system, but I just don't have the time right now.
Old Mar 16, 2021 | 12:14 PM
VinceC5's Avatar
VinceC5
Leave the subs. Turn down the bass setting on your HU. Turn up the bass on the amp for the rear sub. (assuming you will have an amp or interface with a control ****). You will be missing a lot of sound if you disconnect the front door subs.
Old Mar 16, 2021 | 08:14 PM
TorchRedFred's Avatar
TorchRedFred
I don't really consider the door speakers subs. 10" woofer, imo.
Old Mar 16, 2021 | 08:26 PM
madsonp's Avatar
madsonp
Old Mar 16, 2021 | 08:27 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Old Mar 17, 2021 | 12:36 PM
FAUEE's Avatar
FAUEE
They are the gray area between great midbass and crappy subwoofer.
To Unplug/remove door subs with trunk sub?
