Head unit for a 2006 C6
I started a thread on the C6 Tech/Perf Forum that probably belongs here.
https://www.corvetteforum.com/forums...head-unit.html
Last week I bought an '06 that has a single DIN Boss head unit that I want to replace with something with better aesthetics and gives me at a minimum Bluetooth and AUX Input capabilities. One suggestion was to buy an OEM unit and add Bluetooth and AUX which sounds good but now that I look at the units available on Ebay I don't see an AUX in port either in the front or back. Does anyone know anything about that?
I am considering putting in a full screen double DIN unit as well. This is what is currently in the car
If you're attached to the look-and-feel of the OEM LCD + buttons head units, go to www.kawal.net to find out more about your AUX input options. I believe you will need a Tech 2 or the like to unlock any used OEM radio to work with your car.
If on the other hand you're considering a touch screen style head unit, forget about OEM. They're totally outclassed by what's available in the aftermarket.
