Switched power supply?
If the stereo was installed correctly, some sort of interface should have been used, it may differ than the one shown above. If they didn't use an interface, and just spliced into the wiring, this can cause all sorts of issues. The interfaces have the wiring for switched and constant power as you can see here.
The first thing I suggest you do is determine if you have an interface, and determine the brand, then go to that companies web site and look at the installation instructions for wiring it up. If you don't have an interface you might have a whole other can of worms. If you're not sure, post a photo of what you have, and we could probably help you through it.
but I didn't think this would be easy. Here are a couple more photos both into and out of the 24-pin connector. There are two connectors that plug into the BOSS, one for the speakers and one for power, antenna/remote, etc.If there is a PAC, would I see it in this area or could it be mounted somewhere else? I doubt it's there, I don't get any chimes at all in the car.
I am totally up for installing an interface and making things right, I just hope there is a way forward on that and that the original wiring has not been screwed up to the point where that is not feasible.
https://www.corvetteforum.com/how-to...igation-368176
I pulled the center console today, wasn't too bad but some of those connectors put up quite a struggle. After getting it out and gaining more access, I saw that all those extra wires are routed to the left side of the car and run underneath the door. If I had taken a hard look before tearing into it I would have seen that, sigh.
As for the interface...looking at the PAC unit I am now not so sure I it is worth the effort in my case. Here is a list of what it is supposed to do:
- Retains OnStar® and functions when the factory radio is replaced
- Retains steering wheel controls (pre-programmed)
- Retains factory Bluetooth (2009+ model vehicles)
- Retains rear seat audio controls
- Retains all warning chimes (chime module included)
- Retains back-up sensors/park assist
- Retains factory BOSE and premium Bose audio systems (Does not retain fade in digital systems)
- Compatible with non-amplified audio systems
- Chime volume adjustment (factory buttons)
- Rear Seat Entertainment Retention
- Retained accessory power output (RAP)
- Reverse Wire output
- VSS (Vehicle Speed Sense) output
- Illumination output, Parking brake output
- Includes antenna adapter
OnStar retention - If you subscribe to OnStar you'll want this feature.
Steering wheel controls - If you car has this feature, you'll want this. If your car doesn't have these I can give you some guidance on how to add them if you're interested.
Bluetooth retention - chances are if you get a new head unit that has Bluetooth built into it, you won't need this.
Rear seat audio (RSE) and audio controls - of course the Vette's don't need this as we have no rear seats.
Warning chimes - These are good to have a retain to have the car chimes to warn you of certain things i.e. if you leave your head lights on.
Backup sensors - Not needed on the Vette.
Retains Bose - This is something you'll wand it running the stock amplifier, even if it not "Bose" because all Corvettes have a stock amplifier
Retained accessory power (RAP)- with this, the power to the head unit remains on when you shut the car off, until a door is opened or 10 minutes passes, then it shuts it off automatically. Good to have if you're waiting in the car for the wife to come out of the store.
Reverse wire output - needed if you install a backup camera (which I highly recommend), This activates the head unit to display the camera automatically anytime the car is put in reverse. I personally also installed a front camera on my car which is handy to help avoid damage to the front end when pulling up to parking blocks.
Vehicle speed sensor (VSS) - Needed if you get a aftermarket Navigation head unit which makes it more accurate, also used on some non navigations specific units to make smart phone navigation more accurate vis CarPlay etc.
Illumination output - This is needed to dim the display of the head unit automatically whenever the head lights are turn on, some of the head units with screens can be bright, so it's a good feature to retain.
Parking Brake output - This is needed to make some changes on some head units, so you don't try to make them while driving potentially distracting you, it unlocks these features when the car is stopped, and the parking brake applied. There're was to bypass thiis however if you choose to.
I'm personally running the GM1A-RST in mine, with my Pioneer navigation system, and I also have steering wheel controls. The OnStar retention wasn't needed in my case because OnStar is no longer supported on my car, so to disable this feature on the interface, I just pulled the OnStar fues in the fuse panel. So I hope this help you make a decision, let me know if you have any other questions.
Looks like one of the POs installed a big sound system in the car, pulled it before selling it but left all the cables.
So when I get the interface I guess I have some wiring to sort out. The only wiring schematic I have is in my Haynes manual and it is not really helping much.The ones I have found on the forum are not readable, is there a good source that you know of?
Jim
Jim
So this connector will plug into the factory connector in place of the one shown above.
