Sponsored by: Innova
No Sound From Radio
Old Sep 22, 2023 | 10:47 PM
Wanted_zo6's Avatar
Wanted_zo6
Default No Sound From Radio
Hello everyone, I have a 2006 Zo6 that has an issue with its OEM BOSE system. Radio comes on but no sound will come from any station. The AMP fuse is fine. I checked all fuses just in case and all passed. I removed the amp and plugged it back in (yes I know but was worth a shot) that didn’t work. I am kinda stumped. Do I need a new amp?
Old Sep 22, 2023 | 11:02 PM
TorchRedFred's Avatar
TorchRedFred
Do you still have the stock head unit installed or do you have an aftermarket head unit?
Old Sep 22, 2023 | 11:13 PM
Wanted_zo6's Avatar
Wanted_zo6
it is the stock head unit
Old Sep 22, 2023 | 11:35 PM
TorchRedFred
The earlier C6's, like your 2006, the door woofers have their own separate built in amp. Not sure this helps, but I would think that you would still get some sound even if the other amp went bad. Hopefully someone else can chime in and be more helpful.
Old Sep 23, 2023 | 01:04 AM
torquetube's Avatar
torquetube
Do the chimes work?
Old Sep 23, 2023 | 10:11 AM
Wanted_zo6's Avatar
Wanted_zo6
Originally Posted by torquetube
Do the chimes work?
it does not appear so. Only slight beeping noises when selecting radio stations.
Old Sep 23, 2023 | 10:29 AM
torquetube's Avatar
torquetube
The OEM system generates chimes and beeps within the head unit. They go through the amp to the speakers just like other audio signals. If you hear beeps when you press the traction control or DIC buttons, that much of the system is working.
Old Sep 23, 2023 | 04:33 PM
TorchRedFred
You can try picking up a used amp off ebay or the forums for sale section to try and trouble shoot it with parts. If that doesn't work, it may be a good time to upgrade the head unit.
Old Sep 23, 2023 | 04:52 PM
Wanted_zo6's Avatar
Wanted_zo6
I am not getting any chimes or beeps
Old Oct 26, 2023 | 09:23 PM
Wanted_zo6's Avatar
Wanted_zo6
I installed a new amp and still having the same issue. Tried putting a CD in the head unit to see if maybe it’s the antenna but it won’t even accept the cd. Will not suck the CD in.
Old Oct 26, 2023 | 09:54 PM
TorchRedFred
Trouble shooting can be a pain in the @. Do you think it could be a bad head unit? If so you can pick up a used one but you would need to get it unlocked by a dealership or garage. Or you could go with an aftermarket unit. Many of us, including myself, were never happy with the oem head unit.
Old Oct 27, 2023 | 01:05 PM
Sha-Booty's Avatar
Sha-Booty
So you checked the fuse for both the radio and the amp?
Old Oct 27, 2023 | 08:52 PM
Wanted_zo6's Avatar
Wanted_zo6
All fuses are good I’ve checked them all about 7 times now lol
Old Oct 27, 2023 | 08:53 PM
Wanted_zo6's Avatar
Wanted_zo6
I ordered a new aftermarket head unit online and will install it and see what happens
Old Nov 25, 2023 | 09:32 AM
Wanted_zo6's Avatar
Wanted_zo6
Just wanted to give an update. I have a new aftermarket head unit and everything, went to install it, and I was sent the incorrect pac wiring harness. Soooo I put it all back together and guess what? I got chimes and the radio worked!! You can imagine how happy I was. Thennnnn this morning was leaving to go get coffee. No chimes. No music. Lol.
Old Nov 26, 2023 | 09:20 PM
jcgunn's Avatar
jcgunn
So, the PCBs in C5 electronics look like something out of 1970s High School electronics shop. They are prone to cold/broken solder joints. (see HVAC bright/dim fix threads). Sounds like your wires are good. If you want to keep the OEM H/U, you could try finding a used one and see what happens...
Old Dec 8, 2023 | 05:24 PM
GaryZ06's Avatar
GaryZ06
I am having the same issue in my 2006 with the base stock unit.....Once in a while it will work but 99% of the time it does not
To No Sound From Radio
