Sponsored by: Innova
Battery connection
Old Sep 23, 2024 | 11:02 AM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
Default Battery connection
So for those with the battery in the rear, there is NOT much room. What are you using to connect your amps to the battery???
Old Oct 2, 2024 | 10:22 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
I used an aftermarket connector that has a built in splitter. It's tight with the extra cable but it works. Then I used a y at the amps in my amp box.
Old Oct 2, 2024 | 11:34 AM
Geoff13IOM6GS
you got a picture or brand or link?
Old Oct 2, 2024 | 12:58 PM
madsonp's Avatar
madsonp
Not sure if the rear battery cars are the same, but I connected my subwoofer amp to the positive battery post on the under hood fuse box, that comes directly off the battery, then ran the positive lead back to my amp. The neg connection for the amp you want to ground as close to the amp as possible.
To Battery connection
