Sponsored by: Innova
Woofers
Old Apr 28, 2025 | 09:13 PM
walleyejack's Avatar
walleyejack
Default Woofers
last winter i had a Kenwood installed, and upgraded the tweets to a better solution. I noticed
the last cpl days the woofers are not working.. not sure how long this has been going on, I have the fader set to 75% rear and lots of base there.. so never noticed none in front until today. the Bose fuse is good, the relay is good. wireing is good and still connected. the woofs are good, I have run out ideas,, When adjust the fade to full front, left and right, all is there is the tweets.. any thoughts or ideas be appreiciated.
2002 Z
thanks Al
Old Apr 28, 2025 | 10:42 PM
VinceC5's Avatar
VinceC5
1. Radio amp trigger not working. Check for 12v at the blue/white radio wire.
2. Adapter not triggering the amp to turn on. Would have to check for voltage at the amp in the door.
3. Both amps in the doors are bad (very unlikely) check for AC voltage at the outputs.
Old Apr 29, 2025 | 01:04 PM
TorchRedFred's Avatar
TorchRedFred
It could be your wiring interface. Wen I was doing my install, I realized all the speakers were not coming on until I pushed and held the plug into the interface. As soon as I let go, some speakers would cut out. I replaced the adapter (interface) box with another and worked fine after that.
Old Apr 29, 2025 | 10:17 PM
walleyejack
ok.. thanks for the input.. i talked to the installer today and said for sure they were working, something simple i am sure.. I am electronicly challenged.. lol anything else am good with, have an appointment to take to ths
shop thursday. says he will look at it.. has to be simple
Old Apr 29, 2025 | 10:26 PM
madsonp's Avatar
madsonp
Vince, if this were the case, wouldn’t he have no sound at all ?
Old Apr 30, 2025 | 08:52 AM
VinceC5's Avatar
VinceC5
highs run from radio amp. Woofers have a dedicated amp.
Old Apr 30, 2025 | 10:41 PM
walleyejack
could it be an issue with PAC connections ?
Old May 1, 2025 | 03:17 PM
VinceC5's Avatar
VinceC5
if they worked before, then not an issue with the connections, but perhaps an issue with the connection or plug deteriorating over time.
Old May 1, 2025 | 05:31 PM
madsonp's Avatar
madsonp
Didn’t know that, I thought they all ran through the stock amp, thanks for enlightening me with you infinite wisdom once again Vince.
Old May 13, 2025 | 10:12 PM
walleyejack
dbl post
Old May 14, 2025 | 06:26 PM
CJL64's Avatar
CJL64
depends who installed it. Go back to the person who did the kenwood. I am guessing they put in the adapter.
Old May 15, 2025 | 12:06 PM
walleyejack
MODS close this thread please.
Old May 15, 2025 | 01:03 PM
NBVette_Canada's Avatar
NBVette_Canada
While it isn't typical to close a thread until a solution has been found and relayed to all those that were interested or helped by offering things to check, since you are the originator of the thread, you are rightly able to ask for it to be closed.
It would be nice to make a final post stating that the issue has been found and corrected, what the problem and solution was, etc.
Old May 15, 2025 | 03:47 PM
walleyejack
Hi I have another post that I posted a while ago and I forgot about this one and it was going down. So I have another one that is active and I'm getting lots of help with it.
thanks
To Woofers
