Sponsored by: Innova
Best Place for Ground
Old Mar 2, 2003 | 11:31 PM
knesbitt's Avatar
knesbitt
Default Best Place for Ground
I am installing my amps and would like to know where is best place to find ground in engine compartment. Also, do I need to drill hole through engine compartment to supply power to my amps?
Old Mar 2, 2003 | 11:37 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Best Place for Ground (knesbitt)
Your ground wire should be a short as possible... So unless you're planning on installing your amps in the engine compartment you'll need a better spot somewhere in the car itself. The frame is always a good spot, I'm sure others can tell you where they hooked up theirs to. :cheers:
[Modified by Metal_Wulf, 11:37 PM 3/2/2003]
Old Mar 3, 2003 | 01:15 AM
pdd000's Avatar
pdd000
Default Re: Best Place for Ground (Metal_Wulf)
im runnin my grd to the seat bolts in ba ck of the seats
To Best Place for Ground
