Sponsored by: Innova
Sub install question
Old Mar 9, 2003 | 11:30 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Sub install question
Hi,
I have seen many people installed their sub reversely, the magnet on top like Michael in our forum.
What diff between that installation and the normal installation?
On my HU, it got the setup for sub to be reversed.
And how much volume do you build for that kind of reverse box?
I love the look of my sub magnet :D so I wanna build it like that :D
Thanks :cheers:
[Modified by mike76002, 4:30 PM 3/9/2003]
Old Mar 9, 2003 | 11:53 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Sub install question (mike76002)
the only diff between regular install and reverse is you get to see the back of the sub and not the top...installation is the same as is the required enclosure size.
Old Mar 9, 2003 | 12:02 PM
M396 #00-011's Avatar
M396 #00-011
Default Re: Sub install question (Metal_Wulf)
Minus speaker displacement. Which isn't really much at all, even for a JL W7 :eek:
Old Mar 9, 2003 | 03:04 PM
Conquer's Avatar
Conquer
St. Jude Contributor
Awhile back I inverted my 2 12's and got a much better sound. I feel that was do to a small gain in air space from the enclosure I was using.
Old Mar 9, 2003 | 03:20 PM
0Vette Stripes
Former Vendor
Default Re: Sub install question (Conquer)
Thanks y'all
:cheers:
Old Mar 12, 2003 | 01:17 AM
GTLocke13's Avatar
GTLocke13
Don't forget to add the volume inside the cone to the enclosure volume. A rough calculation should be sufficient to give you some idea of what that volume is.
Old Mar 12, 2003 | 01:28 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Sub install question (GTLocke13)
you don't need to be that exact :crazy:
Old Mar 12, 2003 | 11:00 AM
GTLocke13's Avatar
GTLocke13
Depends on the box. Just doing some rough calculations for a 12" speaker, I'm getting somewhere between .1 and .2 cu ft. If you're running a 1.5 cu ft box, it's not that significant, but if your box is only .5 cu ft, you may want to account for it.
I figured the volume using a cone with a radius of 5 inches and a depth of 2 inches, then guesstimate how much volume you lose due to the dust cap in the middle.
Old Mar 12, 2003 | 11:53 AM
0Vette Stripes
Former Vendor
Thanks y'all again.
I really wanna do it but still don't have a good design yet so still hold on to the existing setup.
:cheers:
To Sub install question
