Sponsored by: Innova
Problem With ACC
Old Mar 28, 2003 | 10:31 AM
knesbitt's Avatar
knesbitt
Default Problem With ACC
I wired up the Passenger fuse compartment for 12+ switched and am getting voltage all the way to the HU wiring harness. I am also getting negative to the wiring harness. I am not getting HU to switch on. I tested the ACC connector on wiring harness and it appears that I am getting no signal. I tested ACC by connecting to ground and connecting to the pin that ACC goes to on the wiring harness and got nothing. Do I have to by pass the wiring harness for acc and splice off of another wire like I did with +12V? The HU works on my bench so I do not believe that there is problem with the HU. Any help would be appreciated.
Old Mar 28, 2003 | 10:43 AM
leolufse's Avatar
leolufse
Default Re: Problem With ACC (knesbitt)
I just emailed you. :seeya
Old Mar 28, 2003 | 01:23 PM
MVP's Avatar
MVP
Default Re: Problem With ACC (leolufse)
Please share. :thumbs:
To Problem With ACC
