Sponsored by: Innova
95 Non-Bose problems
Old Mar 31, 2003 | 06:08 PM
LT1TKO's Avatar
LT1TKO
Default 95 Non-Bose problems
At first it was going out every now and then. Now the radio does not come on at all and the antenna does't even come up any more. I think something got wet and shorted it out. I checked the fuse box and the fuse is still good. The radio lights up when you start the car but its just a blank screen. What could be the problem and will replaceing the head unit and speakers fix this. Thanks for your help.
Old Mar 31, 2003 | 09:46 PM
bogus's Avatar
bogus
Default Re: 95 Non-Bose problems (LT1TKO)
I know a bit about the Bose... but the Delco... I donno...
But my gut says the problem is in the head.
And after this many years, heads die... speakers rot...
I would replace... your getting lights, I would assume the curcuit works ok.
it also makes sense, considering the antenna does not work right, either.
Old Apr 2, 2003 | 11:30 AM
sundbergjc's Avatar
sundbergjc
Default Re: 95 Non-Bose problems (bogus)
I have a non Bose 95 LT1, 6M. I can talk speakers but not head unit
Old Apr 3, 2003 | 11:13 PM
LT1TKO's Avatar
LT1TKO
Thanks for the help. I will check on a new receiver this weekend. probably an Alpine. I'll keep you posted.
To 95 Non-Bose problems
