Most component sets, like most speakers, are rated at a 4 ohm impedance.
The question is, is that per speaker, or per set?
If it is per set, then the final load on the amp is 4 ohms per channel.
If it is per speaker, and since there are actually 2 speakers per channel, you would halve the impedance and the amp would actually see a 2 ohm load per channel (assuming the speakers themselves are each 4 ohms).
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Re: Question about component inpedance (leolufse)
They are 4-Ohm unless otherwise specified, like the Image Dynamics CXS62's, they are 2-Ohm stereo component sets. The CXS64's are 4-Ohm. Not many companies make 2-Ohm separate systems.
The Blose speakers are 1 ohm impedance. Most stereos are set to drive 4 ohms per channel. I ended-up replacing my speakers when I put in a new stereo. If you had two 4 ohm speakers on one channel (why?) then the stereo would see 2 ohms, but it wants to see 4 ohms. Tweeters usually have filter circuits to direct the highs to the tweeter and lows to the bass speaker, and that circuit should have 4 ohms input impedance when both speakers are plugged-in.
Re: Question about component inpedance (stanandsue)
crossover networks are designed for specific speaker impedances. If you change a driver with another that has a different impedance, you also change the characteristics of the crossover frequency.
Re: Question about component inpedance (Mike Mercury)
The impedance rating of components is per set. With a crossover the drivers are never on at the same time; well actually they overlap at the crossover -3dB point, but they're both down 3dB. The point is the amp pretty much sees 4 ohms.
Now if you hooked up a tweeter and a mid in parallel without a x-over that's different (and stupid.)
:cheers: This is the answer I was looking for, thx.
