Sponsored by: Innova
JL Audio TR525-CX
Old Jul 2, 2003 | 09:30 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Default JL Audio TR525-CX
I installed a set of JL Audio TR525-CX in the rear of my 99 C5, and they sound terrible. :eek: Is this a plug and play or do I need to do something else?
:confused:
Thanks :seeya
I found the problem, on my Alpine HU if you have the sub-woofer mode enabled it routes output to the sub-woofer. If there aren’t sub-woofers connected the sub-woofer mode needs to be disabled. Did that and it sounds much better now and have good volume control.
Thanks for all your help, it is comforting to know that if you have a problem there is somewhere to turn and great people willing to help.
Have a Great Day! :party:
[Modified by budmont, 1:14 PM 7/3/2003]
Old Jul 3, 2003 | 12:37 AM
1COOLPC's Avatar
1COOLPC
Default Re: JL Audio TR525-CX (budmont)
What do they sound like? Describe why they sound poorly to you.
Old Jul 3, 2003 | 08:42 AM
budmont's Avatar
budmont
Default Re: JL Audio TR525-CX (1COOLPC)
Not much volume, have to tune the fader mostly to the rear to hear them. The quality of the sound is what you get from a cheap old time transistor radio I had back in the early 60’s. After reading all the stories on the forum about how bad the bose speakers are compared to after-market units I thought I would try to upgrade the sound quality. :cheers:
Old Jul 3, 2003 | 10:40 AM
1COOLPC's Avatar
1COOLPC
Did the speakers you took out and the speakers you put in all have the same resistance? (Ohms.) Check to make sure that it matches up. For example, if you take a 4 ohm speaker out you will need to replace it with another 4 ohm speaker. Thanks.
Old Jul 3, 2003 | 10:59 AM
leolufse's Avatar
leolufse
Perhaps you wired them out of phase. How did you determine which speaker wire was + and which one was - ?
Old Jul 3, 2003 | 11:16 AM
budmont's Avatar
budmont
Default Re: JL Audio TR525-CX (leolufse)
I have a 99 C5 wiring diagram, so I'm sure that the + & - are correct. I double checked them twice. :cheers:
Old Jul 3, 2003 | 11:33 AM
budmont's Avatar
budmont
The replacements are 4 ohm, can't find the ohm rating on the bose speakers. :cheers:
To JL Audio TR525-CX
