Sponsored by: Innova
Stereo install help for a '91
Old Aug 27, 2003 | 12:01 PM
TA's Avatar
TA
Default Stereo install help for a '91
I am getting ready to dump the Bose gold system in my '91 and have a few question regarding the install. I am ditching the entire Bose system, but I'm not going crazy (at least yet) with my new system. I'm planning on simply installing a new head unit and new speakers (5.25" fronts/6x9 rears). I might possibly install an amp or subs down the road, but for now I'm sticking with the HU/speakers. I'm fairly confident I'll be able to get the speakers and the new HU fitted, but my question regards wiring. In the past when I've installed stereos in cars I've simply spliced an aftermarket wiring harness onto the new head unit and plugged it into the factory wiring harness. I'm assuming though that this isn't going to be the case with the Bose system. I know I have to run new speaker wire to the new speakers as Bose stuff isn't compatible, but can I still use some type of wire harness or am I best off just finding the wires I need and splicing? Any input would be appreciated. Thanks,
Tom
Old Aug 28, 2003 | 10:16 AM
90EXPVette's Avatar
90EXPVette
Default Re: Stereo install help for a '91 (TA)
You're definately going to need to pick up a wiring harness. The Bose in our Vettes are probably different from anything else you've seen (I know it was for me). The head unit is just a controller (like a home stereo radio receiver or CD Player) the "radio receiver" is located under the passenger side hush panel along with the antenna. So you'll have to run wires from the receiver under the dash to your new head unit...the rest is normal.
Old Aug 28, 2003 | 10:53 AM
TA's Avatar
TA
Thanks for the reply. Can I use a "run of the mill" wiring harness for a typical GM radio or do they make something specific to the Blose?
Old Aug 29, 2003 | 02:08 AM
90EXPVette's Avatar
90EXPVette
Here's what I bought:
http://www.tune-town.com/Cars/stuff/...t_Corvette.htm
You'll need the harness and the antenna extension to run from the receiver to your new HU
Old Aug 29, 2003 | 07:49 AM
TA's Avatar
TA
Default Re: Stereo install help for a '91 (90EXPVette)
Old Aug 29, 2003 | 07:50 AM
90EXPVette's Avatar
90EXPVette
My pleasure :cheers:
To Stereo install help for a '91
