Sponsored by: Innova
Ok you audio freaks, answer this
Old Dec 29, 2003 | 07:14 PM
Zambroski's Avatar
Zambroski
Default Ok you audio freaks, answer this
I have a 350 watt amp (mono) running into a 300 watt rated sub. I used a 2-30 watt rated RCA output adapter. All is perfect wiring with no problems (kinda **** that way), but, I have the head unit, the Rca adapter and the amp all to maximum output to get enough bass which I think is a little weird. I tapped into the front speakers for more low signal so, do I need a larger Amp or is it possible to get a better (bigger watt) rca output adapter to draw more power?? Anyone......Bueller............????????? ???????
Old Dec 29, 2003 | 07:49 PM
Kale's Avatar
Kale
Default Re: Ok you audio freaks, answer this (Zambroski)
what sub, what amp?
Old Dec 29, 2003 | 08:32 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: Ok you audio freaks, answer this (Kale)
:iagree:
and we are audio SUPER freaks :lol:
Old Dec 29, 2003 | 08:37 PM
Zambroski's Avatar
Zambroski
Alpine mrp-m350 amp class D , alpine type R 12" rated for 300W
Old Dec 29, 2003 | 09:25 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
If you want more bass you will need more amp power. The Type-R sub can take more power than the MRP-M350 can dish out. The Type-R can handle 500W and an MRD-M500 with a RUX-4280 would be a great match.
Old Dec 29, 2003 | 10:38 PM
EatRice's Avatar
EatRice
Default Re: Ok you audio freaks, answer this (rbartick)
I agree with rbartick but I would also get your signal off the rear speakers and use the xover built into the amp.
Old Dec 30, 2003 | 08:12 AM
Zambroski's Avatar
Zambroski
Default Re: Ok you audio freaks, answer this (EatRice)
Thanks guys. Are you sure about tapping into the back speakers? Everyone on the boards until now seemed to believe not to tap the back speakers as they are not a full range signal. I wouldn't mind trying the backs but if it is not going to make enough difference (or worse, no difference) then I am starting to "butcher" what little wiring they leave to work on already. It is already starting to look like frankenstein back there. I've got to get it cleaned up (and possibly soldered) before I put the screws (neck bolts :D ) back in for good. I was thinking maybe I could get more power from a better Rca line adapter, does that make sense????????
Old Dec 30, 2003 | 09:28 AM
RussBt's Avatar
RussBt
Not really. You will see no real gain here as long as the current RCA adapter you have is sending the amp a complete source signal in the .2V to 4V range. The MRP-M350 does have speaker level inputs so you may want to try those.
I have no experience with modifying the BOSE setup so I am not sure about the issues involved with adding an external amp to it. You should read this ->TECH TIP<-
[Modified by rbartick, 10:27 AM 12/30/2003]
Old Dec 30, 2003 | 09:39 AM
leolufse's Avatar
leolufse
What is the model of the speaker level adapter you are using? Also, which front speakers did you tap into, there are 2 of them. I tried to help a guy who was running the same amp and sub you are trying. We only got a limited signal out of the converter. He ended up replacing the HU and the same amp/sub set up acted like it was suppose to.
Old Dec 30, 2003 | 09:58 AM
Zambroski's Avatar
Zambroski
Default Re: Ok you audio freaks, answer this (leolufse)
I don't know what year it is. I tapped the tan/black and lt grn/black
To Ok you audio freaks, answer this
