Sponsored by: Innova
(Subwoofer problem) Ok. I'm stumped.
Old Aug 17, 2004 | 10:59 PM
Kale's Avatar
Kale
Default (Subwoofer problem) Ok. I'm stumped.
IDMAX in a ported box, 1000 watts, alpine 7998.
Its very, very, very loud, and nice.
My EQ settings were 400-4 1k -3 4k -3
Well, i'm listening to music and realised its missing some detail. So I set DEFEAT to on. (Defeat turns the EQ off basically.) and noticed a dramatic reduction in bass.
I turned defeat OFF, and it was still quiet.
Example, Korn Ya'll Wanna single? has a nice BOOM BOOM BOOM at the start of the track. Well, it sounded MUCH quieter and.... different.
Almost as if I'd accidentally turned the gains down 40% or so, then set the lowpass at 50hz.
The alpine's xover was still 80hz 24db. I set it to OFF, and it still played at the same volume, and I cuold hear 'more' coming out of the sub. So its not the xover.
I pulled each RCA cable... both were hot. (I've had one RCA cable break on me before.)
I tested the sub with a multimeter... continuity ok all around. Visually, it looks perfect.
I zero'd the gains on my amp, and set them again, 1:1....
no help.
I'm at a loss.
Any ideas?
Old Aug 18, 2004 | 05:17 AM
USA-VET's Avatar
USA-VET
The first thing I would do is pull the sub and run it on a different system!
Old Aug 18, 2004 | 09:21 AM
EatRice's Avatar
EatRice
Eq settings you posted should have nothing to do with your sub. But why do you have them drop so much? That is alot attenuation across the board.
Odd problem with the sub. Hard to except...why are the RCA cables hot? I have never ever had a hot RCA cable. That is where I would start. I would run a new set of RCA from source to amp above the carpet and try it.
Old Aug 18, 2004 | 02:42 PM
Kale's Avatar
Kale
OH sorry, by hot, i mean they both had a signal through them and weren't dead.
My system has some MASSIVE spikes at those levels. I could actually bring 1k down even more, and it wouldn't be in line with the the rest of the system.
Old Aug 18, 2004 | 04:56 PM
leolufse's Avatar
leolufse
That "defeat" mode really messes things up. Check to make sure that your sub level is back to where is it suppose to be, that your sub setting is turned to "on" and "mono" and the sub is in phase.
Old Aug 18, 2004 | 05:08 PM
Kale's Avatar
Kale
Those are the first things I checked. I think I'm going to disconnect hte battery for a while tonight and just start from scratch on the Alpine.
Old Aug 19, 2004 | 12:26 AM
EatRice's Avatar
EatRice
How does the defeat mode mess anything up?
That is a strange problem Kale. Have you been able to measure actually db's or use an RTA to see what the subs are doing. Almost seems like one is blown or you have problem with electronics. Have you tried to use your front or rear RCA cable to feed the sub instead of the sub output? I am guessing that you are using the sub out.
Old Aug 19, 2004 | 01:38 AM
Kale's Avatar
Kale
yeah, using the sub out. Only have 1 sub.
I wonder if the box blew a significant leak? Hmn...
its a huge box, i cant even get to teh back of it.
But a leak wouldn't make it tune LOWER, it would tune HIGHER, yes?
Hmn..
Old Aug 19, 2004 | 07:46 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
That's what I would do...it's a lot easier than trying to track down a phantom problem with the deck.
Old Aug 23, 2004 | 11:16 PM
ModdestMan's Avatar
ModdestMan
Korn sucks
Old Aug 24, 2004 | 06:35 AM
Kale's Avatar
Kale
Originally Posted by ModdestMan
Korn sucks
That was extremely helpful and completely not at all a waste of forum bandwidth.
Old Aug 25, 2004 | 09:04 AM
knewblewkorvette's Avatar
knewblewkorvette
To waste more space....KORN RULES!! The bass notes in their best song (IMO) "Blind" are teeth rattlers.
Old Aug 25, 2004 | 03:35 PM
leolufse's Avatar
leolufse
Did you figure this out yet Kale?
Old Aug 25, 2004 | 04:00 PM
Kale's Avatar
Kale
The problem solved itself last nightt.. so weird.
To (Subwoofer problem) Ok. I'm stumped.
