Sponsored by: Innova
Help with bose interface
Old Oct 31, 2004 | 11:01 PM
saber's Avatar
saber
Default Help with bose interface
I have a 01 Z06 and getting ready to make a partition/sub box.
What is the best bose interface to tap a high impedance signal for a sub. I would like a plugin unit.
Any recomendations and where to buy one?
Thanks in advance.
Old Nov 1, 2004 | 10:26 PM
splash's Avatar
splash
I think most people here are not sure about what you want. So lets see if I can help. 1. do you have a amplifier 2. are you asking about amplifier. 3. you will not be able to run a sub of the stock bose system with out a amp. Hope this helps.
Old Nov 2, 2004 | 04:31 AM
sebringsilver97coupe's Avatar
as posted in the C5 general section, pac-audio.com makes a plug in interface that gives u preamp RCA outs for hook up to the amp for the sub.
Old Nov 3, 2004 | 02:22 PM
utrico's Avatar
utrico
Looking at pac-audio.com which interface do I need? I pulled out the bose system in my C5 and I am trying to put an aftermarket deck in.
Old Nov 3, 2004 | 02:52 PM
bogus's Avatar
bogus
jeez, dude... don't use the blose speakers, they are the reason is sounds so crappy.
most adaptors create more noise than music. I would ditch the entire system and do it right.
Old Nov 3, 2004 | 04:06 PM
utrico's Avatar
utrico
Yeah I am ditching the speakers...I just confused myself on this whole thing and things are starting to clear up. My problem was that I could not find an acc wire and it was driving m crazy. I did not want to wire it to the always on and have to turn the unit on and off everytime I got in the car. I have now read that I can either take the acc wire from around the kick panel or the ignition. That should solve all of my problems and allow me to use the harness I have hooked up right now. I replaced the speakers and I am putting in a sub so it should sound good once I am done. I hate Bose!
Old Nov 3, 2004 | 10:56 PM
saber's Avatar
saber
got a pac audio interface - thanks
Old Nov 4, 2004 | 08:42 AM
knewblewkorvette's Avatar
knewblewkorvette
don't thank anybody yet, you might not be happy
I also agree with Bogus
To Help with bose interface
