Sponsored by: Innova
sound system
Old Nov 26, 2004 | 07:37 PM
luvshervetnfl's Avatar
luvshervetnfl
Default sound system
I really, really, really love my car, and when I'm not listening to the engine, I enjoy listening to the stereo. However, I'm not really pleased with the sound system. Does anyone have any suggestions on how I can upgrade it? I need lots more bass. Thanks!
Old Nov 26, 2004 | 08:07 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
600 Watts Amp, 12" sub in custom box in main storage area.
Alpine IVA-D900 (DVD, NAV, 6 Disc Changer)
MB Quart Platinum Series (Front)Alpine Titanium Speaker (Rear)
Old Nov 28, 2004 | 11:04 PM
luvshervetnfl
Thanks for passing your idea on....one word: WOW!! Thanks again!
Old Nov 28, 2004 | 11:09 PM
GrayC5's Avatar
GrayC5
Have you checked over in the Audio/Electronics section of the Forum for ideas? Good luck finding the system you like.
Old Nov 28, 2004 | 11:12 PM
EatRice's Avatar
EatRice
luvshervetnfl, you can add a sub and amp to your factory system. That will up your bass response. Or you can dump your entire factory system like MyVetteDream did. Adding a sub will cost less and make a nice differance in the way your stereo sounds. Swapping the entire system out can bring your stereo up to a whole new level. You have to decide which is right for you and how much money you want to spend. You can contact me if you want more info at SoundsGr8@hotmail.com.
Randy
Old Nov 29, 2004 | 12:14 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Get the PAC adapter and run amps and subs.
Old Nov 29, 2004 | 12:23 AM
towercontroller's Avatar
towercontroller
Default Pac
I have pics of my stereo under my name. I tried the whole PAC thing but always experienced some minor problems with it. It was nice though to add some bass and keep the factory system. But after hearing what a "real" system sounds like, I had to upgrade. If you can afford it, change the factory speakers and radio and go with a nice system, it really improves the driving experience. good luck
Old Nov 29, 2004 | 12:28 AM
vetterlatethannever's Avatar
vetterlatethannever
Just to add some bass, this would work fine.
GettReal's Avatar
GettReal
I went the PAC route and added an amp and 12" sub.....sounds great for the money invested, llet me know if you want pics of the finished job or install
Old Nov 29, 2004 | 12:45 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Gut it.
I have an alpine deck,
Hifonics 5 channel amp
JL audio components up front
JL 2 ways in the back
JL audio stealth box sub
It pounds, and is clear as day.
Good luck
Old Nov 29, 2004 | 11:00 AM
plaster's Avatar
plaster
I went to Best Buy this weekend to do exactly this. They had a module ($29)that can just be spliced into the existing speaker wire, then an amp/sub can be added?? Would like to see your pics and if this is what they were talking about.
Old Nov 29, 2004 | 11:05 AM
noran01's Avatar
noran01
That 'module' scares me. I have a feeling its a line output converter. Not to mention they can be had for about $5. let me guess, it looks like a little box with RCA's coming out and 4 speaker leads along with (possibly) a power and ground wire? I would definately suggest geting the PAC adapter instead.
I actually had a AVIC-N1 installed (by myself) in my '04 Coupe with the soundgate adapter. After hours of tweaking and playing i couldn't get the system to perform the way i thought it should sound so i went back to stock. Now, i never replaced the amps or speakers, i was only using the headunit with the soundgate adapter to interface with the stock Bose system (that was probbaly my problem ).
Good luck with whatever route you choose!
Old Nov 29, 2004 | 05:41 PM
wit2pz's Avatar
wit2pz
Guys, does anybody have any intel on a touch screen head end unit like the one in the C6?
Old Nov 29, 2004 | 07:43 PM
Blue Lion's Avatar
Blue Lion
I added an Alpine amp and 10" sub and it sounds sooo much better.
Old Nov 29, 2004 | 09:43 PM
luvshervetnfl
Default Sound system
Thanks for all of the helpful advice!! I'm going to get started on it next week...thanks again! You people are great!
To sound system
