Sponsored by: Innova
CD Chander install
Old Jan 15, 2005 | 10:40 PM
harleyrules's Avatar
harleyrules
Default CD Changer install
Anyone have link that works that tells you how to add a factory 12 CD Changer in a 2004?
Old Jan 15, 2005 | 10:43 PM
bogus's Avatar
bogus
think we would give you a bad link?
It's quite easy, really... all you need is the GM changer (or is that chander?) and the cable.
The rest is a bunch of phillips and torx screws.
have fun.
really.
lots.
Old Jan 15, 2005 | 10:53 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Rich,
all you need to do is find the two plugs in the passenger side footwell, one has 3 wires the other has 4, the changer harness plugs into these two and then you just run the harness (down the right (passenger side) side of the car to the center rear compartment, the harness just plugs into the changer.
the changer will be shipped monday.
Old Jan 16, 2005 | 09:19 AM
harleyrules
Thanks Tom,
Okay, how do I mount the mounting bracket?
Old Jan 16, 2005 | 10:18 AM
RPOZ4Z's Avatar
RPOZ4Z
it bolts to the rear of the center compartment.
there is another forum member who used velcro to mount the changer, he said that it's very secure.
Old Jan 16, 2005 | 10:29 AM
harleyrules
Any drilling or epoxy needed?
Old Jan 16, 2005 | 01:54 PM
RPOZ4Z's Avatar
RPOZ4Z
I used self tapping screws, but a more secure way would be to use epoxy with the screws.
To CD Chander install
