FS: LG G2 Coilovers
yarberrymt (06-16-2016)
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Now that being said, since the G2's are all built to order probably need to go over the build data and see if they wouldn't need a spring and/or valve change in the shock.
You could even put them on your new C6Z if you wanted to.
Thanks Anthony for the clarification. My new z has Bilstein shocks and I am happy with the way it is currently setup. I did love these but I don't want to mess with seems to be working on the new car.
So I have edited my add. These will fit all C5 and C6 cars.
Actually they will. You would have to change the rear upper shock mounts as they put them in a different location for the C6 vs the C5 cars but yes they will work.
Former Vendor
Spring rates should be on the spings themselves, either as a sticker by the Hyperco logo, or engraved into the top of each spring.
C5 car, I'm going to say it is a 650 or 700 front and a 600 or 650 rear just shooting from the hip.
Former Vendor
Depends on what you are going to do with your car, but I'm going to assume more straight light use, correct?
More that direction, yes, but want to do some autocross and road track time also.
