helmets
Old Jan 5, 2008 | 01:00 PM
racerjon1's Avatar
racerjon1
Originally Posted by Bill Hetzel
Anyone who drives on the track with their shield up is an idiot.
I've been hit, dead center, by a bird and either a piece of engine block or piston at over 100. Neither broke the shield. But, it wasn't a cheap helmit/shield like some guys use.
When I first started racing, I was given one of the good shields to replace my "OEM" one on my Bell Helmet, at my second drivers school, I was hit dead-center shield by a chain link off of an F500, I was doing probably 110mph.. it is to date, the loudest noise I have ever heard.
I couldn't find the mark on the shield.
Spend the money, buy good stuff.
Yes that was in an open-wheel car, but as an instructor in closed cars, and as a driver I have had cockpits get filled with sand, grass, debris, rocks and all kinds of other stuff.. I have been hit with rubber off of tires, and seen other debris go into cockpits.
I 100% suggest closed face, good shields, clean them, take care of them. The "no full face with airbags" was a report from a research on F1 cars.. not even street cars.
Jon K
Old Jan 5, 2008 | 01:09 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Originally Posted by CodeBlack
This is a job for MYTHBUSTERS
Bring cash and we will get you fitted up at Oval Speed this week. Then some driving shoes and gloves.
Old Jan 5, 2008 | 01:46 PM
Z06cool's Avatar
Z06cool
Anyone have problems fogging up the shield with it down? Or does this go to getting a higher priced helmet with better ventilation?
Old Jan 5, 2008 | 02:23 PM
Lancer033's Avatar
Lancer033
Originally Posted by heavychevy
You wont get hit by a bird in a closed cockpit car, nor a piece of engine block. What you are talking about is applicable in open wheel racing, but not so much DE's and closed wheel .
When you're on the track that's true. You don't need a helmet then either, in fact, helmets actually do more harm than good if you stay on the track.
However, as soon as you go off, stuff starts flying everywhere, and that's when you NEED a good full face helmet. Read AU N EGL's post about getting hit in the chin with his side view mirror
Originally Posted by AU N EGL
I slide into a tire wall on a wet day few years ago. My drivers side door mirror hit the tire wall, folded and popped the mirror glass out. That mirror glass hit my chin gaurd then landed over on the right side of the dash.
If I had an open face helmet, I bet my chin would have been broken.
Old Jan 5, 2008 | 02:40 PM
racerjon1's Avatar
racerjon1
Depending on the weather (temp/humidity) I have had problems with helmets fogging from $150 helmets to $900 helmets..
I have heard anti-fog stuff can help, but have never used it, I do notice that fogging will be less when wearing a balaclava over your nose and mouth.
What I usually do is make a roll of tape about 4-5mm thick, I then put it on the helmet where the bottom edge of the visor comes to, close the visor and it lets just enough air in to stop the fogging.
Jon K
Old Jan 5, 2008 | 02:57 PM
AU N EGL's Avatar
AU N EGL
I leave mine open a little bit. No more then 1/8" to get additional air in.
Old Jan 5, 2008 | 05:55 PM
Steve L's Avatar
Steve L
is there a preference for helmets for PDA or HPDE events meaning open or closed face styles
You can go with open or closed face in PDA or NASA , but I would go with a closed face , I can't tell you how many times a piece of something has come through my side window and hit me in helmet !
Old Jan 5, 2008 | 06:36 PM
Z06cool's Avatar
Z06cool
Jon K
I don't have an excuse for not using the shield then. I'll put it back on and try to leave a gap to see if that helps.. I have on rare occasion had tire marbles hit me without the shield.
Old Jan 5, 2008 | 07:08 PM
John Shiels
my shield stays up about 1/2" gap by it's self. Anti fogs work pretty good also. They even make anti-fog shields
Old Jan 5, 2008 | 07:17 PM
John Shiels
http://www.simpsonraceproducts.com/p...s/Helmets.aspx
3 lb.
CodeBlack's Avatar
CodeBlack
John do you wear ballet slippers when you race
Old Jan 5, 2008 | 08:41 PM
John Shiels
only if you show up
Old Jan 5, 2008 | 08:55 PM
  #33
CodeBlack's Avatar
CodeBlack
I was trying to find custom fit helmets and couldn't locate any is there a web site for them and do they make a difference.
Old Jan 5, 2008 | 09:10 PM
  #34
c4cruiser's Avatar
c4cruiser
Most helmets (whether they are motorcycle, auto racing, or snomobile) either use your hat size or you measure the circumfrence of your head at a certain point and use that dimension in a table to cross-reference a manufacturer's size value. Some low end helmets just use values like small, medium, or large, and those choices even use a range of hat sizes.
One thing that you may find that similar sizes from different manufacturers may not fit the same. I have found that the same size helmet from Bell and Simpson do not fit my head the same way. It really helps to try on helmets to get a good fit.
Old Jan 5, 2008 | 09:18 PM
  #35
Tintin's Avatar
Tintin
Cartoon Character
Jon K
I had a co-driver in Firehawk years ago who left a gap and burned his retinas in a gasoline fireball in the cockpit after a wreck. I keep mine closed tight and use the Fog Off product which works perfectly to keep everything clear. Now that I am approaching codger age, I think my next helmet will have forced air which will allow me to be comfortable with no fog at all...
Old Jan 5, 2008 | 09:20 PM
  #36
CodeBlack's Avatar
CodeBlack
THANKS, that is part of what I was looking for. I will not order through the internet based on that, sure don't need that mistake. THANKS
Old Jan 6, 2008 | 01:00 AM
  #37
racerjon1's Avatar
racerjon1
I have thought about that danger, but I have also considered the fact that there is a pretty substantial gap in front of your chin - making the "air tight" for fire protection kind of hard to do anyway, I have figured, perhaps incorrectly, that the shield is more of a debris shield.. is there other evidence to suggest otherwise? (perhaps fuel vapors find it easier to get in through a few-mm gap in the shield than from the bottom?)
I do wear a balaclava always.. as it gives me more protection and also protects the helmet, though, the eyes are going to be exposed with that as well.
I suppose the anser is to do the drag racing helmet skirts that seal off the bottom as well..
Jon K
To helmets
Old Jan 6, 2008 | 07:32 AM
  #38
AU N EGL's Avatar
AU N EGL
YES my next helmet will have a side air vent and put a HEPA Filter in the blower. Hopefully this will keep the exhaust fumes to a minium.
Old Jan 6, 2008 | 08:26 AM
  #39
Tintin's Avatar
Tintin
Cartoon Character
Jon K
There is not mush of a gap under your helmet if you are wearing a neck donut and these flash fires are usually over in a millisecond. With sustained fire, you will pull your Halon switch in under a second before you jump from the car and run a 2 second 100 metre away from the heat ask me how I know...
Old Jan 6, 2008 | 09:05 AM
  #40
outnumbered's Avatar
outnumbered
I have an ImpactZ helmet. Very light and comfortable. You only get a brief fog when you close the shield. It goes away by itself in seconds.
The ventilation is very good. You can actually feel the air coming in.
I used to run with the shield up until I got blasted with some sand/grit and a chunk? Probably a track turd. It felt like a rock.
