C6 Wheel Sizes for Road Racing
Old 10-14-2008, 11:23 AM
jkittleson
jkittleson's Avatar
Default C6 Wheel Sizes for Road Racing
I want to order some C14 wheels dedicated for track use. I am currently running 18X10's in the front and 19x13's in the rear. What is the optimum wheel and tires sizes to run at the track? Besides tire choice, is there a compelling reason to run 18's front and rear? Would a 17" rear wheel be better than an 18" for the rear?
What tires sizes would you recommend? Tire choice will most likely be Hoosier R6's.
Thanks.
Old 10-14-2008, 02:44 PM
bowmanized
bowmanized's Avatar
Thanks.
18x11 and 18x13, 315/345 HooHoos
Old 10-14-2008, 08:45 PM
Silverton
Silverton's Avatar
How do you get 18x11 front and 18x13 rear wheels to fit on a C6? Even more, how do you get 315/345 tires to fit?
I've got CCW C10's at 18x11 in the front: they stick out even with -1.7 deg. camber!
Old 10-14-2008, 08:53 PM
jkittleson
jkittleson's Avatar
Not sure how he is doing it. 10" is the largest C6 front wheels that will fit. My CCW 505's are 13" with the Z06 rear fenders.
I may just run some Hoosiers on these for awhile...
Old 10-15-2008, 08:31 AM
urslooow
urslooow's Avatar
I have a c6 z w/ 18 x 11 front w/ 295 fronts and the tire hits the wheel well when turned close to full, 345 rears work well on 18 x13 wheels. I would assume the same size Hoosiers would work ok?
Old 10-15-2008, 08:58 AM
Zee0hh6ix
Zee0hh6ix's Avatar
I believe this is for a C6Z setup. I'm running -2.5 camber in front and they do not rub the fender, but will hit the brake cooling duct at full lock.
Old 10-15-2008, 05:48 PM
jkittleson
jkittleson's Avatar
What about Pilot Sport Cups instead of the Hoosiers?
Anyone having issues with the difference in OD front and rear, as they are over 5% different?
Old 10-15-2008, 07:40 PM
gkmccready
gkmccready's Avatar
Depends on how much camber you run. I have 18x11s on my car. At -2deg up front they tuck in nicely, you will want a steering limiter, though. I have 18x11 rears, too, but I think an 18x12 just might fit!
Old 10-16-2008, 02:50 AM
SteveC6R
SteveC6R's Avatar
I have 18x11's on all 4 corners with 315s. No issues except for full lock and that is mainly with the drivers side inner fender wheel. If GM would have located the coolant tank in a different place, it wouldn't be a issue at all.
Old 10-16-2008, 08:01 AM
AU N EGL
AU N EGL's Avatar
turn all the nannies off and you wont have a problem.
Old 10-16-2008, 12:01 PM
jkittleson
jkittleson's Avatar
Cool....thanks
Old 10-17-2008, 03:23 PM
Silverton
Silverton's Avatar
Uh, I thought that was for C5's only.
Old 10-19-2008, 03:22 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
My track wheels are CCW C10's 11” x 18” all around with Kumho 710 tires...305/30/ZR18 front – 315/35/ZR18 rear. I use hub extenders (or spacers) on the front wheels. This has worked very well for me.
Eventually, I'm going to tub my wheels wells to go with 12" rear wheels on the track and so a big brake setup will work better with my street wheels.
Old 10-19-2008, 03:50 PM
AU N EGL
AU N EGL's Avatar
C6s too. If not an aftermarket tuner can change those tables
Old 10-19-2008, 10:06 PM
Silverton
Silverton's Avatar
Can you help the rest of us understand how it's possible to make this work on a C6 non-Z06? Are you using a wide-body kit?
Old 10-19-2008, 11:28 PM
gkmccready
gkmccready's Avatar
I've talked to Steve in the past, but I too run 18x11 front and rear. 295/30r18 front, 305/35r18 rear Toyo R888s. The fronts really really want a steering limiter so you don't slam the wheel in to the wheelhouse or the tie-rods. And you *must* run close to -2deg camber or better up front to get things to clear.
I'm actually thinking an 18x12 rear wheel will fit if you're willing to run -1.5 or better for camber back there.
It can definitely be done. It just depends on where your point-of-view is.
Old 10-20-2008, 07:34 AM
AU N EGL
AU N EGL's Avatar
neg camber. -2.0* or more up front and -1.0 to -1.5* in back which you
and Hoosiers need -3.0 up front and -2.0 in back if not a bit more.
with the proper amount of neg camber the tires wont stick out beyond the fender if that is what you are worried about.
To C6 Wheel Sizes for Road Racing
Old 10-20-2008, 08:13 PM
SteveC6R
SteveC6R's Avatar
I've been at -1.8 and was just fine. This setup works just fine for the car but your going to chew up the inner fender wells at full lock, mainly the driver side due to the over flow tank location. This isn't a issue at National type courses and I only have the problem bacause our local courses usually have a turn around that forces a full lock to make the turn.
But to answer the other question, no, I do not have a wide body kit. When people ask me if it's a Z06 I tell them yeah, it's a special order slim body kit.
Old 10-20-2008, 10:28 PM
Silverton
Silverton's Avatar
I was specifically referring to his comment:
with 315s
As you know, I'm also running 18x11's in front with 295/30-18's. I know that 315's will fit out back, but nobody makes a 315/35-18, except Kumho's 710's. But using 315's in front , it's just hard to imagine. I do have steering rack limiters for my front 18x11's. They severely limit steering for a daily driver IMO. BTW, I'd be happy with 18x11.5's in the back. if 18x12's don't fit so good.
Old 10-20-2008, 11:11 PM
gkmccready
gkmccready's Avatar
I think the RAFT cars run 315s on C5Z 18x10.5 on the C6s. I had forgotten you were running the 295s, too. :-) FWIW, every time I add more negative to the front of the car, the happier the car gets...
Quick Reply: C6 Wheel Sizes for Road Racing
